'15 Clunky Shifting?
Old Mar 14, 2016 | 09:53 PM
roguesturgeon's Avatar
Hey everyone, I'm new to the boards, so pardon anything that I say that might seem "noobish."
I just picked up a '15 Evo X GSR, with 8k on it, which I'm already loving, but I'm noticing something when shifting that isn't what I'm used to; when I go into gear, I often hear what sounds like a mechanical "clunk," not really a grind or anything (I sure know what that sounds like), but it just doesn't seem smooth. When I'm extra firm with the clutch, pinning it to the bottom with more vigor, this doesn't seem to happen as much. I also don't hear it when downshifting via the double-clutch technique.
So, .1) What is this?
2.) Should I be concerned?
2.b) If so, what should I do?
Thank you very much, I look forward to my time here!
Old Mar 15, 2016 | 08:08 AM
jakgal04's Avatar
Its fairly common on all model years honestly. My 2008 does it, mostly in the 2nd -> 3rd gear change.
Old Mar 15, 2016 | 08:13 AM
Ok, that's good news. So it isn't something I have to worry about causing any problems then?
Old Mar 15, 2016 | 09:06 AM
rcb213's Avatar
After you change your diff fluids and trans fluid. The clunky shifting will get better.
Old Mar 15, 2016 | 09:14 AM
jakgal04's Avatar
Not at all. Its just one of those characteristic Evo things Like rcb213 said, if you replace the trans fluids to amsoil or redline it'll help out a bit.
Old Mar 15, 2016 | 04:11 PM
AngryEvo's Avatar
I have driven 4 new ones and they all have the 2-3rd clunk.
Old Mar 16, 2016 | 02:16 PM
moparfan's Avatar
Mine does if I'm being sloppy or not really paying attention. The issue as I see it on my car is the clutch doesn't really disengage where I think it does. If I make sure to depress the clutch all the way, I don't get a clunk however fast I'm trying to shift.
Also, thus rarely happens when then temp is about mid 60 or so. I bought my Evo in November - what a ***** it was getting in gear at times. It's much, much better now. It shifts very well now. If this Evo shifted as well as a Mazda 2 manual I would probably have list my license by now. I got used to doing in gear pulls because the next gear was often hard to get into when the car was new.
Old Mar 17, 2016 | 09:36 AM
LetsGetThisDone's Avatar
I have found that Amsoil 75w90, as well as replacing the underhood shifter linkage bushings helps a decent amount. But just like the 8/9 5 speed, they are just a notchy gear box..
Kainvorador
22
Dec 18, 2008 05:55 PM
moreryce
Aug 25, 2008 05:32 AM
Methodical4u
16
Jun 29, 2008 03:27 PM
Lightsped
Nov 1, 2004 05:58 AM
lancer03_Mike
Lancer Troubleshooting
24
Jan 17, 2004 10:20 AM
