First Oil change and transmission grind
I have a 2014 GSR with 1,200 miles on it and I've noticed the shifter has a stiff feel to it, but I've never had a problem getting it into gear. Every once in a while it doesn't like to go into reverse after startup but I just play with it a little (go first gear, blip gas, then reverse) and it's fine.
I actually kind of like the "mechanical" feel of the shift lever. A little different than other manuals I've driven, but it feels sturdy and more rigid. Makes it feel a little more like a high end sports car with slotted gear box.
As far as the oil change is concerned, I plan on changing my oil at 2,500 miles and going to full synthetic from dealership. Probably won't do the other fluids until 15,000 miles or if mechanics notice anything.
pb91
Jun 8, 2011 02:44 PM
