Evo X Stage 1 questions
Going to begin modifying my Evo X and was just wondering what is a "stage 1" mod.
Do you guys also recommend a cobb acessport?
If I'm in the wrong forum side, I am sorry. Please forgive me!
This is going to be a dumb question. By exhaust you mean just the end part right? Because when i look it up its showing my the straight/down/and exhaust.
Can you also maybe link me some intakes and exhaust you recommend.
Here you go, they make some great products.
http://extremeturbosystems.com
I would recommend getting, UICP, intake, full exhaust (with high flow cat or test pipe) intercooler, 3 port. You should be able to make 315-320 with those mods.
you cannot do any of this without a tune, and, that will take care of check engine lights anyways
Go the Cobb route, its a little more money, but buy this http://www.cobbtuning.com/Mitsubishi-Evo-X-Stage3-Power-Package-w-Oval-Tip-p/652xv3o.htm and you'll have nothing to worry about. Mismatch parts and you might have issues. The Cobb AP is all the tune you'll need to be safe if you're buying Cobb parts, and then if you get a proper tune later on you'll gain even more HP
Then when you're ready, you can add on a TB exhaust and flash to stage 2 map. You can then go a step further and add the EBC and flash to stage 3 (not sure if additional mods are needed).
The cobb ap also allows for easy monitoring and logging. Also clears codes and I'm sure a few other things.
