Sponsored by:
Sponsored by: CARiD
Evo X Stage 1 questions
Old Feb 21, 2014 | 07:00 AM
alg626's Avatar
Originally Posted by DatEvoLance
I usually use 93. 320 HP would be fine with me.
Also would you recommend a access port?
I had my car tuned at TopSpeed here in Atlanta. 93 Oct. Drop-In Filter, Cat-Back Exhaust with High Flow Cat, and a Electronice Boost Controller(Cobb 3 Port) and made 345whp. Just throwing that out there so you have a target. Also those numbers are from a DynoJet.
Old Feb 21, 2014 | 08:38 AM
Landshark's Avatar
Originally Posted by ikt
"Stage 1" is general understood to be an intake and cat back only exhaust. You'd need a tune, too.
stage 1 is a flash/tune
stage 2 adds catless/high flow catted exhaust (turbo back)
stage 3 is open to debate - used to mean a turbo swap, now Cobb adds an EBC?
Old Feb 21, 2014 | 11:45 AM
DatEvoLance's Avatar
Another question would be the difference between catless/turbo back and catted. I know cat means catalytic converter. But what are the benefits and downfall of getting catless and stuff
I ordered the AP already. I don't know what a UICP.
By leaning out what do you mean? Also would you recommend gauges?
Old Feb 21, 2014 | 12:42 PM
bphx123's Avatar
Of course you want to go catless you'll notice huge gains there. UICP=Upper intercooler pipe. And I'm sure everyone would advise you to get the AFR (Air Fuel Gauge) Good luck with your build
Old Feb 21, 2014 | 03:59 PM
TrogdorWBL's Avatar
Originally Posted by TrogdorWBL
There is no unified meaning of "stage __." That's why the term is so dumb.
See, my point exactly. There is no one definition for "Stage ___."
And yes, if you go catless you will throw a CEL, unless you have your car tuned by an actual person. Unless you plan to try to "ninja mod" your car (i.e. Keep a warranty LOLOLOLOLOL), or want to use multiple tunes, an AP isn't worth the $400 or whatever.
Old Feb 21, 2014 | 04:04 PM
ChUt26's Avatar
You can find v2 AP's for about $200 in the classifieds
Old Feb 21, 2014 | 04:07 PM
I DON't want CEL light. That thing has ALWAYS haunted me. Plus if i go to inspect the car every year I don't want any worries.
I'm probably going to just get a UICP, a intake, a catback exhaust with the accessport.
Old Feb 21, 2014 | 04:14 PM
ChUt26's Avatar
The CEL is easy to get rid of. If you're worried about inspection then just get a high flow cat.
Old Feb 21, 2014 | 04:15 PM
randycsvt's Avatar
The best bang for your buck mods are
1. Test pipe
2. 3 port boost controller (I have a grimmspeed)
3. A good tune
I have other supporting mods, but these three got me about 100whp and 100wtq
If you just want to make some good power on the cheap, I would try those first.
If you can spend some more money I would add an intake and exhaust to make it sound good and probably a uicp.
Old Feb 22, 2014 | 07:30 AM
TrogdorWBL's Avatar
1. Test pipe
Depends on emission testing in your state.
Old Feb 22, 2014 | 12:06 PM
Landshark's Avatar
there is, if you go by Cobb's staged tuning. at least for 1 and 2 there is.
haxr303
Mitsubishi TC-SST Discussion
Oct 30, 2023 07:26 PM
EvoNo0b
Cobb AccessPORT
May 3, 2015 01:40 PM
milab21
Jul 28, 2014 07:29 AM
Alkaedas_Inc
Dec 30, 2012 01:47 AM
yoshe200
Cobb AccessPORT
29
Apr 5, 2012 06:55 PM
