Sponsored by:
Sponsored by: CARiD
turbo and cams or clutch
Old Mar 6, 2014 | 03:30 AM
Ralliart09er's Avatar
The S2s are the same price most places, may as well get more bang for your buck. Pm strictly modified on here, its where I found the best price for mine.
Old Mar 6, 2014 | 05:46 AM
turbotboz's Avatar
S2's are where its at! PM me if you want a deal on a set.
Old Mar 6, 2014 | 06:08 AM
meckert's Avatar
Looks like your kind of all over the place here.
1) the clutch in the X is the weak link. Many folks dont even keep one in for 10k on an unmodified car before is slips and needs to be replaced.
2) as others have said you need to figure out what you want and the cost, That turbo while a great choice for some is going to be huge for a street car and have power way up in the rpm band instead of where you usually drive-- if you want that great.
3) you need to pick a cam that matches the turbo power band. So the S1 while again a great cam builds power down low and your turbo selection builds power up high and while that sounds like a transition they dont work together. The S2 would get you closer but in my view you need a smaller turbo.
4) if your spending all you have on these mods, better get to work on saving more cause running 450-500hp on a stock bottom end--well regardless of tune may very well be the ticket to a rebuild. Others will disagree, if you have time and a lot of spare cash do what you will.
5) spend some time working thru some of the issues mentioned in the thread and you will save time and money and do it right the first time--again as others have said talk with your tuner and you will be happier in the end. GL
Cyrax91
11
Jun 12, 2015 06:38 AM
TopLevelPerformance
Jun 2, 2014 09:40 AM
michaelwarduk
May 14, 2014 12:58 PM
STALIZE
Jan 16, 2014 09:49 AM
NewEvolutionIX
Jan 15, 2013 12:01 PM
