Sponsored by:
Sponsored by: CARiD
Removing water stains from window?
Old Mar 10, 2014 | 09:03 PM
butters149's Avatar
Hi,
I made the mistake of washing my car in the sun on a sunday morning, so now there are some water marks on the window that I can see, I used some window cleaner but it seems that it hasn't come off.
So just wondering, how do you remove?
Old Mar 10, 2014 | 09:58 PM
elecan's Avatar
Rewash car, dry with chamois leather if you have much lime in you water.
I always try to the remove water before it can dry and eventually leave a water spot.
Old Mar 11, 2014 | 08:39 AM
Veronica's Avatar
Or try diluted white vinegar in a spray bottle.
Old Mar 11, 2014 | 02:41 PM
ikt's Avatar
ikt
Originally Posted by butters149
Hi,
0000 steel wool and soapy water will take it right off with almost zero effort.
do not rub the steel wool on the paint or door trim! Pro tip: mask off the door trim with tape beforehand.
Old Mar 15, 2014 | 02:50 PM
quadracer111's Avatar
Water and vinegar works well.
Old Mar 15, 2014 | 04:08 PM
AndyCT9W's Avatar
I use a clay bar which is pretty effective for both glass and paint. It gets recent marks off but doesn't do much for the older ones.
I usually towel the car off after washing to minimize the amount of marks.
Old Mar 15, 2014 | 04:55 PM
Roadrunr's Avatar
I had a 1970 AAR Cuda, Dark Green with original paint. I was the second owner. It had the worst case of water spots on the paint, windows and stainless trim. I tried steel wool, rubbing compound and many magic home brews. None of it worked. A friend who was a avid boater said to try water spot remover from the Marine Store. I was amazed, just wipe on and off and it was gone from all surfaces.
Duckeys Water Spot Remover rings a bell, I think. It was like magic.
Old Mar 15, 2014 | 06:12 PM
kaj's Avatar
kaj
i use the same polish as i use on my paint. to speed up the process use a DA or orbital (on glass, not the paint) buffer.
it takes the spots right off.
Old Mar 17, 2014 | 07:32 PM
maxse03's Avatar
I just use the same polish I use on the car.
NorCal Lancer
Mar 27, 2022 11:01 AM
Rrrr
Aug 2, 2015 01:47 PM
Aux.
Jan 25, 2006 10:04 PM
roller
Oct 16, 2005 06:00 PM
