Sponsored by:
Sponsored by: CARiD
engine missfire #1 #2
Old Mar 28, 2014 | 12:50 AM
coolice's Avatar
my methanol kit fuse that is connected to the battery got burned , changed it , started the car , now piston #2 and #4 are not working , checked the coils , injectors and spark plugs <by swapping them> , the are all fine !
can any one suggests what to do ?
could it be a bad MAF ?! or bad ECU ?! crank position sensor ?
grounding wire !!
plz help
evox 2009
Old Mar 28, 2014 | 02:37 AM
mavraolan's Avatar
I can't really help you man, I am not expert. But I am doing some research on methanol kits, for my IX. I read lots of forums and opinions and 90% said that water/meth can only be good for car , many advantages and no disadvantages. If your engine broke (HOPEFULLY NOT) because of that kit I will never install such a kit on my car.
We need an expert here please....
Old Mar 28, 2014 | 11:22 PM
coolice's Avatar
need help plz
Old Mar 29, 2014 | 02:08 AM
jracer's Avatar
Did you do a compression test ? You sure you didn't hydro lock the cylinders ?
Just some ideas .. Your going to have to start with the basics ..
Check compression,spark,fuel, ect ..
Old Mar 29, 2014 | 03:52 AM
coolice's Avatar
i checked it , all are fine ,,, can the cam sensor make the car missfire two cylinders ?
DESERTEAGLE50
Nov 17, 2015 02:13 PM
jason42003
May 5, 2015 11:26 PM
JeyEvo
Dec 10, 2014 12:30 AM
BlackonBlack2
Oct 22, 2014 06:26 PM
