Sponsored by:
Sponsored by: CARiD
Downpipe removal - bolt broke off
Old May 5, 2014 | 09:21 AM
KVandy15's Avatar
I had the same issue, I tried hard to remove it myself using a right angle drill. It didn't work out, the bolts are really hard and if yours is like mine then it's really in there.
I ended up taking it to a local speed shop where they had to remove the turbo, machine it out, and put a coil in. This is about worst case scenario and it ended up costing me about $600.
I know it sucks but taking it to a shop is probably your best bet.
Old May 7, 2014 | 10:50 AM
deanob's Avatar
Taking off the hot side is a lot easier then removing entire turbo. Its literally like 6 bolts + the band clamp and it keeps the turbo lines intact so you dont have to do a coolant flush/oil change.
The machine shop charged me $70 to do the drill/tap.
Old May 7, 2014 | 11:03 AM
Dallas J's Avatar
Veteran: Army
Don't use an extractor on that otherwise you'll be taking it to a shop to extract a broken extractor... The bolt broke in that case cause it seazed, and an extractor isn't going to turn work in this case.
You can pull it off and get a hole centered really well, then drill it out in progressively larger sizes. Eventually youll get a really thin wall and you can file or dremel a slot to break it the rest of the way out.
Other options would to find a machine shop with an EDM machine. I've had many bolts burned out for $20-$30 each. Mitsubishis, both DSMs and Evos, love to gall bolts on the turbo and o2 housing which means turning them out isn't an option.
eisnikesb
May 12, 2014 10:24 AM
ahendrickson
Evo X How Tos / Installations
Apr 16, 2013 05:58 AM
omniprobe
Jun 6, 2011 01:10 PM
Ekoy
Apr 16, 2010 06:52 AM
porque
Jan 8, 2007 03:29 PM
