Sponsored by:
Sponsored by: CARiD
Damn Brembo retainer pins!
Old May 8, 2014 | 05:44 AM
CaptainAsia's Avatar
So last night spent a good hour (along with chewing up part of the covers with dings) trying to get the retainer pins out of the front brakes. They just won't move! Anyone have any tips on getting them out?
Old May 8, 2014 | 06:31 AM
Iowa999's Avatar
Get a nail-setter from any hardware store. Hit with hammer. The key to nail-setters is the pointed tip to keep it from wandering when hit.
Old May 8, 2014 | 07:12 AM
Thanks! Any chance you know what size to get?
Old May 8, 2014 | 08:30 AM
Iowa999's Avatar
I've never thought of size as being important. [Wait. Maybe I should re-express that, in case someone reads more into it than I intended.] The keys are being small enough to not chip the caliper when the pin suddenly moved, having a good point so it doesn't wander, and not being one of those spring-loaded gizmos as they never seem to work correctly.
Old May 8, 2014 | 06:45 PM
Johnr352's Avatar
Too funny, and yes a nail set or a thin philips screw driver works in a pinch. Should come out easy as pie.
Old May 8, 2014 | 07:06 PM
total0wnage's Avatar
i used a metal Punch and a hammer to get the pin to move, then vice grips holding the pin tight hammer the vicegrips
Old May 9, 2014 | 01:01 PM
Sawdust's Avatar
Small
Stanley Nail Set Stanley Nail Set
Old May 9, 2014 | 03:05 PM
ChipperEvo's Avatar
This. I have a set up metal punches I used for the pins on my guns but they work just as well on the caliper pins.
Old May 9, 2014 | 03:09 PM
heel2toe's Avatar
As others have said all you need is a punch, nail or small screwdriver. It is straightforward with the right tools and should take you all of 5 seconds to remove.
Old May 10, 2014 | 09:50 PM
moomeacow's Avatar
yes I did this and worked perfect
Old May 12, 2014 | 08:39 PM
IRPerformance's Avatar
I just use a punch and carefully hit the pins straight on. Never had an issue.
Old May 12, 2014 | 09:15 PM
deylag's Avatar
Why not use this tool?
http://www.racingbrake.com/product-p/ccp01.htm
The punch:
Punch out end
Old May 18, 2014 | 02:02 PM
RaX's Avatar
RaX
Originally Posted by deylag
Thanks for that. Just placed an order.
Old May 18, 2014 | 04:46 PM
rcheung's Avatar
You were hammering the sharp not the blunt end right?
MrCollyns
Nov 17, 2016 04:03 PM
jayt27
Mar 2, 2016 09:50 AM
littlegif1
AEM EMS
Jan 20, 2016 08:41 PM
Evo_AK
16
Sep 28, 2015 12:26 PM
HyperDisorder
Sep 8, 2011 12:12 PM
