Sponsored by:
Sponsored by: CARiD
e85
Old May 28, 2014 | 11:55 PM
elkazX's Avatar
e85
So..I'm thinking about getting an e85 tune. Anything in specific I should be aware of if I do go e85? Will if affect my car in any way? (Besides add power of course) what are some things that could go wrong because of e85, especially in the long run?
Old May 29, 2014 | 02:01 AM
Mick_O's Avatar
Nothing to worry about except added fuel consumption ive been on ethanol in 2 cars for 5 years with no problems at all. I use a trade strength injector cleaner every few tanks to be "safe"
Old May 29, 2014 | 04:55 PM
elkazX's Avatar
Also what injectors and pump would you guys recommend?
Old May 29, 2014 | 04:57 PM
Mick_O's Avatar
how much power you chasing? What turbo?
Old May 29, 2014 | 05:09 PM
leemaster's Avatar
Veteran: Army
Anything above 1000cc BUT depends on what turbo you use AND your hp goals. Dont buy a 1100cc to be 400 whp and then later on upgrade to a 1400cc like this guy here once did lol.
Old May 30, 2014 | 02:22 PM
elkazX's Avatar
Stock turbo, and probably around 450ish. Maybe a little less
Old May 30, 2014 | 02:23 PM
elkazX's Avatar
If I'm trying to get around 450 hp what would you recommend?
Old May 30, 2014 | 07:09 PM
kanovic's Avatar
You will need another turbo for 450ish
Old May 31, 2014 | 12:48 AM
r34p3rex's Avatar
E85 on stock turbo will get you to 400hp. If you want 450, you'll need to upgrade to the MHI turbo or similar (FP red, EF2.5, etc).
You will need at least 1000cc injectors, which will be fine with stock turbo + e85. I'm not sure if 1000cc will be able to keep up with a MHI turbo though. Also, get a 300lph+ pump such as the DW300, Walbro 400 (E85 version), Aeromotive 340
My suggestion is for every 20 tanks of E85, switch back to pump gas for a tank. The solvents in the pump gas will help clean out the gunk in the fuel system.
Old May 31, 2014 | 12:59 AM
shrtstuff89's Avatar
Just go with the 450lph walbro, e85 compatible, then 1400+ injectors which are good for 500+ on e85 more if on pump. Stock turbo wont get you 450 though, youll need an fp red to do that with a stock motor.
Old Jun 2, 2014 | 02:21 PM
elkazX's Avatar
Not looking to upgrade my turbo just yet so I'll go with 1000cc. So the regular pump gas won't mess with my tune or anything if I do go e85?
Old Jun 2, 2014 | 02:40 PM
zmw's Avatar
zmw
having run e85 on every turbo car I've owned since 2003 - you have nothign to worry about, you will make quite a bit more torque because you should spool earlier, if you are running beyond the capacity of the stock turbo it is very likely you'll need fuel upgrades.
gymnasty
E85 / Ethanol
162
May 7, 2018 03:52 PM
dcdirtrider
E85 / Ethanol
19
May 25, 2016 07:39 AM
evo9powerr
12
Aug 5, 2014 02:35 PM
Nagua
May 23, 2014 05:13 AM
05EvoVIII
Apr 5, 2009 08:09 PM
