Sponsored by:
Sponsored by: CARiD
First time doing this input needed.
Old Jun 17, 2014 | 12:47 PM
Jerm6908's Avatar
First let's say i googled it an got answers thrown all over the place from different forums that confused the heck out of me mainly what i saw was HOW to change it... Anyways i'm about to change my fluids an i just want to know is this all i need for the 30k fluid change even though it says 60k is it still the same fluids i need?......An i already did the clutch fluid with ams oil so we can forget that.
http://www.lancershop.com/customer/p...productid=6587
Old Jun 19, 2014 | 09:56 AM
ikt's Avatar
ikt
No gym for home, work out floor with 30, but is it for 20 like 30 lb when you no lift it to be for men, for 30 lbs instead? or half is 10 for 20 pounds?
UMM HOW i word this... ok u take 20 lbs no lifting for 30lb if guy, so divide 2 u dont sit, u get 10 but for guy it no 30, so 20 would be for guy if u werent a girl ?
Old Jun 19, 2014 | 10:46 AM
KruMsz's Avatar
this confuses me so much..
Old Jun 19, 2014 | 10:47 AM
Jerm6908's Avatar
Anyways i went on amazon an ordered this stuff.....Hopefully i get it right an its all i need.
Old Jun 19, 2014 | 11:09 AM
Iowa999's Avatar
I, personally, would have gotten the Redline cocktail for the transmission, but here I'm assuming that the thread-starter has a GSR, while the bit about changing the "clutch fluid" makes me think otherwise.
As to IKT's post, sometimes when I cough really hard, stuff that has been stored in lung-phlegm since the 1970s is released. That's my best guess as to what happened here.
Old Jun 19, 2014 | 11:26 AM
Jerm6908's Avatar
Clutch fluid Don't ask lol......This is 90 weight LSD on other forums someone said 75-90 LSD which is it...Maybe i should take it to a dealer cause to many confusing post on this.
Old Jun 19, 2014 | 11:40 AM
Iowa999's Avatar
I'm not sure why you don't want to talk about the clutch fluid. You either have an MR, instead of a GSR, in which case the answers to your questions are quite different, or you really have a GSR, in which case your "clutch fluid" is brake fluid.
Old Jun 19, 2014 | 12:20 PM
Jerm6908's Avatar
I was reading other things while typing this an that person said clutch fluid had me thinking the same...I have a GSR as my avatar picture shows.
Old Jun 20, 2014 | 11:31 AM
ikt's Avatar
ikt
I'll blame spellcheck
Old Jun 20, 2014 | 01:59 PM
Jerm6908's Avatar
I just got DiaQueen LSD an Mitsubishi ATFIII .......Canceled my motul 90 off amazon just to make life easier.
Old Jun 29, 2014 | 03:41 PM
Jerm6908's Avatar
I got to changing them today it was pretty easy like others said just drain an fill.... My only question is on the rear diff it has 2 fill holes for the gear oil but both are for the same thing correct?
Old Jul 3, 2014 | 01:46 PM
ogarcEVO's Avatar
No, if I remember correctly you add ATF in the rear fill hole and gear oil in the front fill hole.
Old Jul 3, 2014 | 03:14 PM
ikt's Avatar
ikt
no!!! it acts like a clutch, one side is ATF.
Old Jul 4, 2014 | 06:41 AM
Jerm6908's Avatar
Yes on the driver side it says gear oil both fill holes say gear oil one facing the front of the car one facing the rear...On the Passenger side it has the ATF fill hole an drain plug.....Why would they label it gear oil if it is for ATF that makes no sense at all.
Old Jul 4, 2014 | 08:33 AM
Iowa999's Avatar
Too bad there isn't a set of pictures showing what goes where in a sticky-thread at the top of this sub-forum.
