Sponsored by:
Sponsored by: CARiD
Evo x stock tires
Old Jul 18, 2014 | 02:52 PM
Nickbevox's Avatar
Evo x stock tires
Bought my 2014 x new within 9k miles and after some power mods stock tires where shot. I drive the car hard but is the factory alignment bad from mitsubishi?
I ask this because my rear two tires wore pretty even and the front tires wore hard in the inside . ( I know this is from cornering hard ) but the drivers side tire wore through and you could see the thread in the tire the other three where not near as bad.
Any advice when I put new tires on should I get an alignment or is this normal for the evo to wear like that on tire tread?
Old Jul 18, 2014 | 02:56 PM
ChUt26's Avatar
The Evo has a pretty aggressive alignment from the factory. Just make sure to keep up with tire rotations.
Old Jul 18, 2014 | 03:20 PM
SilverShadow03's Avatar
+1..keep up on tire rotations.
You should always get an alignment when installing new tires for your dd.
For my 8, I have 0 toe and factory specs everywhere else. My tire wear is fine and I dd my evo. I know it is not a X so do your homework and see what other X owners have had success with when getting an alignment.
GL!
Old Jul 23, 2014 | 05:45 AM
OhNo5OhGSR's Avatar
I had the same issue at 3k miles, they went so far as to tell me the allignment may have been off from when it came over seas they strapped it down to hard......gotta love dealers
Old Jul 25, 2014 | 08:11 AM
Uscbryan's Avatar
From what I noticed the stock tires don't handle camber very well. When I was running -2 on the front it wore the stocks pretty fast. I'm -3 on AD08's 275/35 with 10k miles and you can hardly see the wear on the inner side.
Old Jul 25, 2014 | 09:34 AM
Raptord's Avatar
As an aside, tires don't wear on the inside from cornering, they wear on the outside (assuming you have stock-like camber)
Old Jul 25, 2014 | 10:04 AM
joescars's Avatar
My stock tires lasted only 12k miles. They wore pretty well. But, I got the X aligned early on at the local suspension shop (Muellerized) and rotated normally. Never been racing, but push it on on/off ramps. :P
Sueporter
May 22, 2017 09:34 PM
Dr-Gonzo
Mar 6, 2017 08:42 PM
barneyb
Sep 19, 2012 12:28 PM
pstl_pete
For Sale - Wheels / Tires
Jun 22, 2011 11:13 AM
Go_Lancer_Go
10
Jan 28, 2011 10:01 AM
