Is the turbo xs "tbe" a real turbo back.
I've waded through threads talking about fitment and build quality and sound, but I can't find the answer to this question. Is it a true turbo back exhaust? All the pictures I see show a test pipe a mid pipe and the axle back section. Does this kit come with a downpipe too? If not, the title is misleading. A true turbo back exhaust has a downpipe. Hence the TURBO part of the name. Otherwise it's a downpipe back exhaust.
So they do make the downpipe. .. yet all the pictures of the system do not include this piece. I put a downpipe on my mazdaspeed6 years ago. It was probably the best bang for the buck. Picked up an easy 30awhp.
It's not the same with the X - the downpipe won't gain you much with the stock turbo. It's also a PITA to install (compared to the other exhaust components.
So then the stock downpipe doesn't have cats in it? I haven't crawled under there and looked yet. Downpipe on a turbo mzr you have to unbolt the front engine mount and loosen rear mount. Then remove the transmission torque mount, jack the engine up and rock it forward to get the stock dp out. Doubt it's any harder than that.
Nope - it doesn't house the cat. The cat is on the next section of pipe immediately downstream of the downpipe. The first O2 sensor is towards the bottom of the downpipe. The good news is, the cars do respond well to a free flowing aftermarket exhaust, and removing the cat is easy. It's just that the difference between a full turbo back exhaust replacement, and one that replaces the cat and cat-back section aren't much different performance wise on a stock turbo car. Not saying don't do the DP, but I personally wouldn't do it until I did a turbo swap (and then do it at the same time).
FS[Northeast]: Turbo Back Exhaust (Invidia / Espelir)
talonkev
Apr 18, 2016 10:44 AM
06EvoIXmr07
Nov 1, 2008 08:49 PM
201Motorsports
33
Oct 4, 2006 09:52 AM
Wrathafier
13
May 27, 2005 12:16 PM
Chris@nolimitmotors
23
Dec 14, 2004 12:07 PM
