Sponsored by:
Sponsored by: CARiD
4wd system service required???
Old Sep 22, 2014 | 08:54 PM
dan718's Avatar
Hey guys, im kind of new to all of this, I did some research before posting but couldn't find a scenario that was similar to mine.
So, i got a flat about 3 weeks ago (front passenger side), got a used tire (had about 85% thread)
Its in better condition that the rest of my tires.
As soon as i put it on I could feel the car pulling towards the left when hitting the gas a little harder than usual. A couple days later the 4wd sys service required light pops up.
Have any of you guys gone through this?
Would it go away after an alignment?
trying to avoid the dealership after being ripped off so many times
thanks in advance!
Old Sep 22, 2014 | 10:17 PM
Napalm_Enema's Avatar
You can't do that man it's an all wheel drive car???
When you lose one tire you need to replace all four. You can't mix and match tires. If you do you can cause serious problems. (Break your transfer case etc.) I don't know what you have damaged so far, but I would first get a matched set of new tires, and then see if the error goes away. If not, dealership time and lesson learned.
Good luck...
Old Sep 23, 2014 | 04:50 AM
Thomar's Avatar
The car is detecting that one wheel is spinning slower than the rest and that's a problem, so it's giving you a warning.
You can't put a tire with more tread on the car than the rest of the tires. All tires need to be the same, and you need to rotate them every 5000 km (or every oil change) or you risk damage to your four-wheel drive system.
Old Sep 23, 2014 | 04:06 PM
elkazX's Avatar
I also have this light but all my tires are the same and have the same amount of tread and such etc...anyone have any idea why else that would happen?
Old Sep 23, 2014 | 04:35 PM
MercuryMR's Avatar
I've read that it will mess up your differentials if you do not use the same tread tires.
Old Sep 23, 2014 | 05:02 PM
.M.'s Avatar
.M.
You can look here also.....
https://www.evolutionm.net/forums/ev...es-merged.html
Old Sep 24, 2014 | 10:13 AM
ikt's Avatar
ikt
thanks in advance!
you need to replace all four tires, and then have the dealership reset your ACD
Old Sep 25, 2014 | 12:59 AM
dan718's Avatar
Thanks for the help guys. Awd is new to me
Will get a set as soon as possible
Old Sep 25, 2014 | 01:01 AM
dan718's Avatar
Any good suggestions on tires?
I'm in NY so I will see snow this winter.
But I don't put a lot of mileage on the car, within the past three years I probably put about 12k miles
Thanks
Old Sep 25, 2014 | 02:54 AM
LB_Reddy's Avatar
lights shows 4wd needs service?Something broke are fluids need to be changed?
Old Sep 25, 2014 | 11:00 AM
ToMinLA's Avatar
I would say. Get a good pair of summer tires and move to L.A.
That is what I did. You will put more miles on your car due to great weather. Check out on you tube. Mulholland Snake. World famous.
Old Sep 25, 2014 | 03:16 PM
Sephiron's Avatar
You can also look for a tire shop that shaves them. It may seem like a waste to shave a new tire down to the old tires wear. But It can save you from having to get a new set of 4.
Old Sep 25, 2014 | 03:44 PM
ikt's Avatar
ikt
not always, that's a common CEL that comes on for all sorts of un-AWD-related ****
Old Sep 25, 2014 | 04:27 PM
.M.'s Avatar
.M.
Never heard of that.
My light actually came on once on the way to the parts store. Started the car 15mins later, light was off. Hasn't come back since. *Knock on wood*
Old Sep 26, 2014 | 11:13 AM
dan718's Avatar
I didn't know that places do that
Thanks for the suggestion
