Sponsored by:
Sponsored by: CARiD
CEL fix on Hi-flow Cat
Old Oct 29, 2014 | 12:32 PM
jallways's Avatar
Veteran: Army
Originally Posted by jallways
The scan tool I bought came in today and it pulled the following codes P0021, P0022, P0023 and P0024 which are all related to cam shaft position timing.
As I stated in my previous post the cel light was gone after the car sat a day and a half and has not returned.
The mods I have are K&N drop in filter, turboxs hi-flow and the Works stealth muffler.
Can someone provide some knowledge where this might be going.
Called the service department at the dealer. They stated that since the cel went out, everything reset and not to worry about bit.
Old Oct 31, 2014 | 05:44 PM
Xuracing's Avatar
Spark plug fouler does the trick. Same issue for my car no problems now
Old Nov 1, 2014 | 10:05 AM
jallways's Avatar
Veteran: Army
I installed with spark plug foulers, not working for me.
Old Nov 6, 2014 | 02:35 PM
Projectjdm's Avatar
Take the cel fix with a grain of salt. It's a hit or miss type thing. Some people run into issues and some are lucky and have no issue at all. Me personally I am running a circuit werks test pipe with an extended bung already welded on and have no issue at all.
Old Nov 7, 2014 | 03:31 AM
jallways's Avatar
Veteran: Army
Its hit or miss, I throw the cel it resets overnight or while I am driving and then pops up again.
I am going to change it out to the oem cat until I can get it tuned.
Old Nov 7, 2014 | 03:32 AM
patkelley's Avatar
Really?? For someone who lives in a non-attainment area (needs emission testing) and would like to keep their warranty (therefore cannot flash the ecu to turn off rear o2 and readiness), this is hardly a grain of salt. If aftermarket cats can't keep the cel off, they are WORTHLESS to most buyers. Again, had I known the turboxs cat pipe would light the cel, I'd have spent $100 less and effed around with non foulers and a test pipe.
Old Nov 19, 2014 | 11:04 PM
stokEd's Avatar
Why would the flash void your warranty? Can't you just flash back to stock before heading to the dealer? (assuming you have OP 2.0 or Cobb AP) Legit question, had an '08 at dealer half a dozen times after flashing my ROM (i.e. removing tuned ROM, replacing with stock ROM) with no problems. That car is gone, back in the market. Curious if the newer model years (been out of the game since '12) have something special going about them.
I ran an HFC because I can't stand the smell of the exhaust without a cat. And neither could people behind me, especially under boost. Cruising mates would make comments. Regardless, sitting in traffic was nauseating. And that thing would have a no chance of passing emissions (talking about mine). Have you gotten an HFC through GA emissions before? I've always had to run the stock cat to pass.
Old Nov 19, 2014 | 11:11 PM
stokEd's Avatar
...to pass emissions in the states I've lived.
KOEvo
Aug 10, 2006 12:08 PM
Blue Evo 8
Jan 9, 2006 12:09 AM
Trustz
Jul 9, 2003 05:06 PM
