Misfire
Misfire
One day, I turned my car on before work. I turned it on and then went to get dressed for work and when I came back to my car it was completely missfiring. I popped my hood while my car was running to check my coil packs and i would remove the electric wires that plug into the coils to see if it made a difference and to see if the coil was ok. Coil #1 did not make a difference when I unplugged it, the other ones did. So i switched coil #1 and #2 to see if it was just the coil. Now when i unplugged the first one, it still did not make a difference. But when i unplugged the 2nd one which was the first before i changed it, did make a difference. So i figured it wasn't to my coil packs. What could this be?? Please help.
Also did you check for any codes? Did you check the gap on the #1 spark plug?
bad plug or bad tune or both
do you have any sort of aftermarket:
injectors? if so, check clips
tacho/anything that reads RPM?: if so, check wire 4 on ECU commonly tapped for RPM but it really a fuel injector lead
i am running lean, I'm waiting for a downpipe to come in before i retune it. I ordered spark plugs from mitsubishi a week ago and they came in today. Took my old ones out, two of them were completely destroyed
replaced them, and my issue was fixed. Thank god it was something so simple, I definitely was thinking it was something way more complicated.
but yeah, usually the simplest answer is the correct one. Evo's aren't mechanically that complicated...spark and fuel. The ECU, however, yeah no not touching that that's why I pay baka the big bucks
if you're running lean, you better be limping around if you're driving it at all, or your just asking for a blown motor brother
thankfully it was only my spark plugs though. But yeah don't mess with that, or else you'll pay even bigger bucks
