URGENT snapped bolt o2 housing ->turbo
Was installing my open dump downpipe and got 4 out of 5 bolts out fine. The easiest bolt to grab with the socket cracked loose and spun out 3 rotations. The bolt seized up, I soaked it in pb blaster and used a torch to try and crack it loose until it finally snapped. The snapped bolt is about 1/8 inch inside the o2 housing and Is still threaded in. My protune is on Saturday so I need to get this car to a shop ASAP Tommorow morning. I'm letting the shop do the work but of course gonna be there to watch and make sure they aren't doing too much extra work to hustle me out money. What would be the routine to solving this headache? I was reading multiple posts already and some users drilled the bolt out while still in the engine bay, some took the hot side turbo out and also the exhaust manifold out and vice versa.
Mine did the same. The only thing I could do was to remove the hot side of the turbo from the compressor wheel and exhaust mani. I then took it to a machine shop to be drilled out and re tapped for $50.
It's pretty easy to remove the hot side, no coolant or oil lines need to be removed.
Good luck
Good luck
Would a ordinary auto shop be able to drill and tap correctly or would it be a better option to bring it to a machine shop? Also does the exhaust mani need to be removed or just unbolt where it meets the turbo? What consists of the hot side of a turbo
my o2 sensor on the cat went throught the same except when i pulled it out it was all stripped.. both on the sensor and the cat.. now i have to buy a new sensor to install back on the test pipe.. and the sensor is close to $500 at the dealership
Good luck
Good luck
Im dreading my stock 08 exhaust system when I upgrade.
Bmurray
14
Aug 4, 2015 07:36 AM
sleeper04
Nov 22, 2011 09:00 PM
Blue Evo 8
Jul 13, 2008 02:20 PM
