Sponsored by:
Sponsored by: CARiD
overall evo x reliability?
Old Mar 13, 2015 | 01:44 PM
Howat's Avatar
Follow on question
Are there any other simple mods that can enhance the reliability of the Evo?
Originally Posted by clxa38
engine itself is good. It comes from the factory with a bad tune. If you want to keep it stock, I would at least run an off the shelf tune from Cobb to keep it even more reliable.
Old Mar 15, 2015 | 09:23 PM
clxa38's Avatar
I recommend replacing the fuel relay to the most current one. Other than that, it's a pretty reliable car. Mitsubishi put a lot of thought into the design of the engine. I just know the factory tune is very lean/rich... one of the two... someone can correct me. Running an off the shelf tune from Cobb will correct that.
Old Mar 16, 2015 | 07:11 AM
Red diamond's Avatar
change your oil and your car will not fail you. 35k miles and no issues.. and yes i do push every so often.
Old Mar 16, 2015 | 01:45 PM
denlin68's Avatar
u could also remove your clutch restrictor pill to have better and more direct clutch engagement. it will make ur clutch last longer too
Old Mar 27, 2015 | 08:16 AM
vassili's Avatar
engine seems rock solid so far after 5 years (2008 MR). here's a list of stuff that broke, not including recalls:
AYC pump ($1200)
AC (2x, covered under warranty)
paid about $2.5K into maintenance (oil change, fluids, brakes) . SST is expensive.
Old Mar 27, 2015 | 09:59 AM
evoxsteez's Avatar
5k miles on mine and still going strong Lol
Old Mar 29, 2015 | 04:01 PM
LB_Reddy's Avatar
AYC pump ($1200)
Do u dd your mr?I only spent $30 for oil change on my mr and bunch of goodys.Yeah sst are expensive rite now.later on price should be lower.
Old Mar 29, 2015 | 05:26 PM
TxFAkuma's Avatar
$30? u got standard oil dude. Yes we don't need synthetic, but we all use it.
Old Mar 29, 2015 | 06:18 PM
LB_Reddy's Avatar
08 mr takes synthetic.I run mobile 1 synthetic.I think 2010+ year were not required for synthetic oil.
Old Apr 10, 2015 | 05:23 AM
evolutionX1989's Avatar
I can tell you, i've had my x for going on 5 years. and had an 03 before my 08. the x is very reliable in my opinion. i have about 97k on her. still original clutch, third set of tires. i've had an issue with my battery...long story haha. and my ayc pump just went out on me, so im getting that fixed under warranty. but other then that its been a great car. i've changed the oil every 3,000 with full synthetic and changed the spark plugs about every 30k and never had an issue
Old Apr 10, 2015 | 01:44 PM
Viegasjuice's Avatar
Seems like a solid vehicle. Nothing that stands out as a "holy **** this will fail inevitably" as there is with most cars. I dont hear about mitsubishi having turbo issues. The new trans in the X is apparantly very solid. The ACD will prob fail but now with warranty up to 100k milea whats their to really worry about? Engine seems like a very good platform so long as everything is done correct
Old Apr 10, 2015 | 02:02 PM
Zj120cn's Avatar
27000 miles 0 issue
Old Apr 11, 2015 | 08:18 PM
alexn103's Avatar
I use synthetic on all my cars but don't all turbo cars need synthetic to prevent from oil sludge in the turbos?
Old Apr 12, 2015 | 11:44 AM
allanjeng's Avatar
for me it's fine overall.
There are little problems, but overall it's a reliable car I would say.
Old Apr 12, 2015 | 01:07 PM
donny_utah's Avatar
Veteran: Army
19,xxx miles on my 2014. Zero problems.
Occasionally get a weak start. Nothing major.
