Sponsored by:
Sponsored by: CARiD
Possible awc pump failure?
Old May 3, 2015 | 12:53 PM
kanovic's Avatar
So I'm driving and I down **** and acs light comes on, can't change any modes and seems like it almost cuts power out. I pull over pump is making a loud *** noise, turn the car off and back on and I can am change all modes and turn the acs on and off but still seems that I can't get on it. I haven't read if a awc pump would cause that or not. Engine seems to rev but just doesn't go as before
Old May 3, 2015 | 04:57 PM
kanovic's Avatar
Thought about over boost but stays right at 25psi a/f stays at 11.1-11.2
Old May 3, 2015 | 08:00 PM
M4J35T1C X's Avatar
First thing you should do is scan your car for codes. A bad pump will not make the car lose power like you are describing. It is possible that your car over boosted and tripped a code, putting the ecu into limp mode. Scan for codes, write them down and then clear them to see if that helps.
Old May 3, 2015 | 08:04 PM
kanovic's Avatar
I am pretty sure it was overboost since i pulled over turned the car off and the light went off and i can switch modes so i think the pump is good. However there are no codes. I hooked up my AP and everything seems fine. Even when it bogs the boost never spikes more then 26psi and my a/f stays 11.1-11.2 at wot..
Old May 3, 2015 | 08:37 PM
M4J35T1C X's Avatar
What are yours mods? Are you tuned? Which AP map are you running? Need a little more info to help narrow down the issue. It may not work but disconnect your battery for 5 mins to reset the ecu.
Old May 4, 2015 | 07:58 AM
kanovic's Avatar
mods are.
ETS V2 turboback exhaust (recirculated downpipe, test pipe and catback)
DW 800cc fuel injectors
Blaqops e85 conversion kit currently running 93
AMS UICP
walbro 255
its had a custom dyno tune on the Ap that has not had one hickup in 2years
kanovic
May 3, 2015 12:48 PM
Shaka oNe
Nov 7, 2014 10:27 PM
adrianTNT
Mar 8, 2013 10:24 AM
xop32
Jul 17, 2012 03:15 PM
