Opinions on Cobb Accessport?
I have the Cobb access port v3 and I like it but in my opinion it's not worth the $500. The ots maps do help and increase power in my opinion but if your gonna get one, get a used one. I see them unmarried on eBay all the time for a lot cheaper. Also, the over boosting can be corrected by purchasing an after market boost controller like grimspeed or the Cobb and also by using a lwg map which sucks you have to buy something else but it's a good upgrade anyway.. Mine will boost to about 26 psi with the lwg stage 2 map. I recently picked up a used Cobb ebc but have yet to install it. I like it but wish I had bought it used. Just my 2 cents for what it's worth....
Um...get a protune asap that is not a good idea. (unless you have a proper protune then carry on)
I currently am running a stage 2 tune with lwg setting. I found that helped with the over boosting from doing research on the Cobb accessport. I have a Cobb ebcs that I plan on installing but I will be changing my map to the Cobb stage 3 tune. I got the accessport cause the closest tuner to me is 2-3 hours away. I plan on getting tuned mid summer. I was trying to state that the lwg option on the tune helps with over boosting or getting a boost controller helps also. If I am wrong please educate me, I don't want to blow up my Evo x before I paid it off haha!
U
Also 2-3 hours isn't a big deal imo. I drove my Subaru 4 hours to get to Cobb in Plano because I knew they were the best to tune my 08 STi at the time.
Now I am fortunate to have a top tuner in my town (Houston) that specializes in EVO's, but I would drive at least 1000 miles or get an e-tune from a reputable shop if I were going to modify my car.
You can definitely run however you want, but I personally just feel ill running things without proper supporting tune because there is no way to know how that is going to end.
When it comes to a material object that costs 10's of thousands to own, and fix if it breaks, I err on the side of caution every time.
Why risk it?
I, personally, wouldn't run any modifications on a turbo based car without a proper pro tune. Basically, anything that changes the volume of air or flow or boost - tune for it. Even if it 'survives' running what you are without a tune, you can still damage components by running too rich or too lean so why risk it just for some quick power?
Why risk it?
Why risk it?
It's a good product if you don't have convenient access to a tuner and/or have limited tuning knowledge. From my experience with my WRXs, MS3, and now X, their OTS maps are fairly conservative which is a good thing I guess, as they have to produce SW and HW that most anybody can manage, in most any environment for most any variation in the X platform (no one X is the same).
That being said, their Stage II map ought to be redefined to make the EBCS mandatory. Myself and 4 other fellow Xers that I know with the AP, have all had boost control issues with the stage II OTS maps, and have had to add the EBCS with "Stage III" OTS SW.
I'm a bit confused on some of this stuff as a probable buyer of a protune in near term.
Can't the AP be used to store the Pro tune and my oem tune? It seems like all the discussion is AP vs protune, and I am assuming folks mean cobb tune vs protune.
I was going to have my car tuned at an extremely reputable evo shop, and they tune as is, but they encourage the AP for logging and such. If you don't get the AP, how do you log data to adjust tune? A PC or tablet I assume?
Kevin
Kevin
Kevin
Kevin
Kevin
Kevin
I was thinking the OP was wanting to pro-tune his car and just have the maps installed on a AP for ease of switching maps if needed.
cobb ap is a waste of money imo once you get a tune on there you cant sell the the thing and keep your tune, you'll lose it and need a re-tune. go open source ftw (i wish i could)
lol im 3 posts up saying i like it, i ****ed up!
