Sponsored by:
Sponsored by: CARiD
When Is Time To Change Your SST Fluid/Filter?
Old Jun 4, 2015 | 01:25 PM
melonfarmer's Avatar
Hey guys, so recently, I bought a used Evo with 60K miles on it. The problem is, I have no idea whether or not the previous owner had already changed the transmission fluid or not. If not, then I have to change it at the 60K mark but if he already changed it, I don't want to go out and spend another 400 dollars on all the fluid/filter.
That being said, I was wondering if there is any quick way to check the quality of my fluid/ filter without doing a full change.
Thanks!
Old Jun 4, 2015 | 05:40 PM
mattlikewhoa's Avatar
I'd do it for piece of mind really...
Old Jun 5, 2015 | 07:47 AM
Napalm_Enema's Avatar
2nded.
It is technically 'due' if they followed the maintenance procedure. Every 30k so just do it and move on knowing it is good.
Old Jun 5, 2015 | 08:01 AM
EVOX84's Avatar
Just had this talk with another person.... here is what i was told
At stock power levels you can (or at least i have) beat on the car a good deal with no issues. Its the high horsepower cars or cars with **** tunes that are breaking things. (excluding the ACD/AYC pump of course....that POS fails if you look at it wrong)
Maintenance is the key factor here. Especially with the SST. I have seen a few SST cars at over 100K, and in speaking with the owners the common service intervals are -
Engine oil/filter every 3/5K (Mitsu recommends 3k i think)
Spark Plugs every 20K
SST filter change every 5K
SST fluid/filter changed every 20K (debatable - some do 30K)
Diff oils every 30K
Fuel pump relay every 30K (this may have changed with the newer version..IDK)
Serpentine belt every 30 K
This is by no means a fully inclusive list, just some common things i have seen high mileage SST owners do.
Old Jun 5, 2015 | 08:52 AM
jakeleclair2000's Avatar
Thanks!
Checking the filter is quite easy. Just unscrew the filter housing and pull the filter out.
The fluid in the filter housing should give you a good idea of overall fluid quality.
I agree with the other comments about changing it for peace of mind (unless the filter/fluid is obviously new).
Old Jun 7, 2015 | 06:41 PM
acas's Avatar
i just bought my 13 with 16k miles on it, since i dont know if the previous owner did it (i doubt it) im just gonna do it anyway next week,
Freebs
Mitsubishi TC-SST Discussion
Sep 4, 2015 10:08 AM
ecl27
12
Mar 3, 2014 10:28 PM
TrailBrake
Oct 1, 2013 02:11 PM
HimynameisWillzyx
South Region
Feb 2, 2013 05:50 PM
