Sponsored by:
Sponsored by: CARiD
Mod choices
Old Jun 29, 2015 | 06:40 AM
Napalm_Enema's Avatar
Mod choices
Do an upper intercooler and lower intercooler pipe do a lot on their own, or do you really need to get the bigger intercooler as well to see any gains? I'm contemplating adding those to my first round of modifications but not sure if it is worth it?
Current mods:
Drop in filter
EBCS
Catted test pipe
Walbro 255 fuel pump
Tune
Any other 'must have's' for a first round of mods?
Old Jun 29, 2015 | 07:18 PM
ChipperEvo's Avatar
I believe you either have a cat or a test pipe. I think you mean a high flow cat.
The mods you mentioned are a good start. I doubt intercooler pipes will net you any power.
Old Jun 30, 2015 | 05:53 AM
shekaar's Avatar
Current mods:
Drop in filter
EBCS
Catted test pipe
Tune
The UICP/LICP don't net any power, and the intercooler doesn't do much in that department either. The upper piping does seem to increase throttle response a bit, and lower charge temps are always a good reason to get an intercooler. The intercooler may give you some small gains, but nothing to write home about.
Old Jun 30, 2015 | 08:23 AM
ETS Michael's Avatar
The upper pipe is worth a bit of power and throttle response due to the instant neck down/restriction in the factory pipe. Instead of starting your intercooler piping at 1.75" (Factory Diameter) you start at 2.5" (ETS Upper Diameter). This mod is very similar to the Evo 8/9 lower pipe.
During our testing we were able to net around a 15-20whp gain over the factory intercooler using our 3.5" intercooler. This gain is due to lower intake temps and more flow through our intercooler core. The factory intercooler is undersized for the application. Sure you have guys that will make 1 good power pull on the factory intercooler, but when you run your car back to back our intercooler is definitely beneficial.
Hope this helps!
Michael
Old Jun 30, 2015 | 08:51 AM
Hope this helps!
Michael
It does, and thank you!
Old Jun 30, 2015 | 01:59 PM
joshpiger's Avatar
Seems like a good start. Also, sorry you caught the modding bug. It gets expensive real quick! (well worth it though)
Davethewave
27
Jan 3, 2010 05:20 PM
the_cosworth
Lancer Aftermarket Forced Induction Tech
44
Sep 28, 2007 03:58 AM
EVO Nathan
Aug 8, 2006 12:07 PM
akinaspeedstars
Jul 1, 2004 02:23 AM
