Sponsored by:
Sponsored by: CARiD
Evo won't start, little play in brake pedal
Old Jun 29, 2015 | 01:07 PM
GSRSTIKILR's Avatar
Veteran: Army
Went to start the Evo today and it wouldn't start. Also noticed that there is very little play with the brake pedal. All the hoses look good. Battery tested as "weak" but still green.. Any ideas?
Old Jun 29, 2015 | 01:25 PM
hoobastnk90's Avatar
Well try jumping the battery or just replacing it first. I doubt the brake pedal has anything to do with it.
Old Jun 29, 2015 | 01:42 PM
GSRSTIKILR's Avatar
Veteran: Army
Tried jumping, no good.
Old Jun 29, 2015 | 01:46 PM
does it crank when you try to jump it?
Old Jun 29, 2015 | 02:58 PM
GSRSTIKILR's Avatar
Veteran: Army
Yes. Sometimes it will for a few seconds then stop
Old Jun 29, 2015 | 06:13 PM
gr8dc2b's Avatar
Have you checked your relays and your spark plugs?
Old Jun 29, 2015 | 07:45 PM
GSRSTIKILR's Avatar
Veteran: Army
So I ended up buying a new battery and it started up on the second try. Thankfully it wasn't anything serious. Weird though since the original battery was testing out as fine. I will check again tomorrow to make sure the issue is resolved. Thanks for the suggestions everyone.
Old Jul 1, 2015 | 01:01 PM
BlackHawk_Tsi's Avatar
battery terminal corrosion?
Old Jul 2, 2015 | 04:27 AM
GSRSTIKILR's Avatar
Veteran: Army
Terminals were good. My buddy said that he seen quite a few cases where after a couple years the battery randomly dies. Weird though since mine had no issues or anything until it randomly decided to die.
Old Jul 2, 2015 | 02:33 PM
That exact thing happend to my DD car. Was perfectly fine the day before never showed any signs of getting weak. Came out the next day it barely started and then turned it off and tried to restart it and it was gone. Was kind of wierd usually they kind of show some signs of dieing first at least in my experience.
Old Jul 7, 2015 | 09:25 AM
Veronica's Avatar
Brake pedal is firm until the car starts and then vacuum builds for the vacuum-assist power brakes.
Batteries can fail internally and yet the green light (chemical composition) is still indicating 'good'.
Old Jul 12, 2015 | 07:38 PM
all batteries can fail prematurely. they tend to swell, seem bloated.
Wmu240
Sep 4, 2015 07:02 PM
HugePwnr
Apr 27, 2014 07:52 AM
denon728
Jul 30, 2006 05:56 PM
viciousv322
Feb 18, 2006 02:19 PM
evo959
Dec 6, 2005 05:34 PM
