Sponsored by:
Sponsored by: CARiD
P0014 help
Old Sep 2, 2015 | 03:48 PM
Hatchyboy91's Avatar
P0014 help
So I had p0014 that is cam sensor, so I checked the chain tension, and replaced the sensor and went to clear the code and it had 2 of the same codes and it let me clear one. But the other says permanent and won't let me clear it. Why is that. Am I missing something
its on a 2010 gsr
Old Sep 2, 2015 | 03:50 PM
i heard that if u change the chain u have to get a reflash from the dearler?????
cuz i just got the car and i think the prev owner changed it when they did head studs
Old Sep 2, 2015 | 04:34 PM
Napalm_Enema's Avatar
Pre 2011 the EVO X had a chance of stretching the timing chain. You need to stop driving - flat bed tow it to a shop, and have that changed immediately. Even if they changed it, they probably did it wrong as you should never have that error.
Good luck, hope you didn't lunch your engine.
P.S. Take it to a good shop, that specializes in EVO's preferably, or if you are unsure just bite the bullet and take it to the dealership.
Old Sep 3, 2015 | 08:08 AM
ChipperEvo's Avatar
FWIW, I had codes 16 and 17 come up about the sensors and my timing chain was fine. I did get it replaced since I was going to do it at 60K anyways but the codes never went away. turns out, there was a TSB out there for these codes and they had to reprogram it (which the dealership told me that my ECU was bad because it was tuned LOL). I don't know if that touches your tune at all but I didn't care as I had my AP to reflash it back.
Old Sep 3, 2015 | 12:01 PM
Yea but if it was stretched wouldn't it run like **** and the timing marks not line up?
Old Sep 3, 2015 | 12:04 PM
Chipperevo when they re-flashed it did it help it ? And did u lose ur tune?
Old Sep 10, 2015 | 08:47 AM
ChipperEvo's Avatar
Sorry just saw this. I don't know what gets reflashed and not sure if it's just for the codes or if they rewrite the whole thing.
The TSB reprogram did work. I haven't seen the code since the reprogram last year.
rkelley
Aug 12, 2015 09:54 PM
8OhOh2
Jul 7, 2015 10:48 AM
KickRocks47
Nov 5, 2012 02:05 AM
overlord2kx
Nov 30, 2010 08:55 AM
boostedgraphite
Oct 13, 2009 07:26 AM
