Sponsored by:
Sponsored by: CARiD
P0014: need some advice
Old Mar 8, 2013 | 07:46 PM
rkelley's Avatar
I've been getting P0014 CEL for exhaust cam timing over advance for a month now on my 08 GSR. I've replaced the cam sensor, oil control feeder valve, oil passages are clear, mivec sprocket mechanism is operational. Don't know what else to do. Anyone have any ideas?
Old Mar 8, 2013 | 10:08 PM
GRAPHITE RALLI's Avatar
Didn't the 08 models have a problem with chain stretch?? Might look into that as an issue
Old Mar 9, 2013 | 05:08 AM
rkelley's Avatar
When I had the valve cover off I noticed I have the updated chain design. I lined up the timing marks and there was zero stretch indicated based on the reference in the service manual.
My car has 35k miles on the odo. Knew I forgot some details.
Old Mar 9, 2013 | 05:52 AM
Johnr352's Avatar
I presume you saw this thread
http://www.gencoupe.com/2-0t-discuss...p0014-cel.html
if not, it might be helpful.
Old Mar 9, 2013 | 07:27 AM
rkelley's Avatar
Already replaced the oil control feeder valve. Thanks though.
Old Mar 9, 2013 | 08:03 AM
acm_evo's Avatar
There is a TSB for your issue. Apparently, there is an issue where the ECU throws codes relating to chain stretch in error. You need to take the car to the dealership and have them use their MUT III tool to have the ECU relearn the chain learned values. After that, they will reflash the ECU with an update. I had this done several months ago, and the CEL has not come back since.
Old Mar 9, 2013 | 08:14 AM
rkelley's Avatar
Thanks for the reply. I had the learned value reset before I installed the new oil control feeder valve. Do you think the new valve will make a difference with the learned values?
Old Mar 9, 2013 | 10:12 AM
acm_evo's Avatar
I don't see how the oil control feeder valve replacement would have any impact on the learned value. When the cam position sensor was replaced, did you replace the right one (exhaust cam and not intake)?
Old Mar 9, 2013 | 10:57 AM
mantella's Avatar
what is your oil pressure and is it good in the head? did you look at the cam gears for cracking? How long have you had the car and do you know what is done to the engine?
Old Mar 9, 2013 | 04:05 PM
rkelley's Avatar
Don't know the oil pressure, should probably invest in a gauge. I disconnected the battery overnight and now I've got a P0011CEL and no P0014. Pulled the intake cam sensor and there was sludge on it. It's been 1100 miles since I changed my oil so I'm going to change it again in the am. Cam gears aeee sound. I've had the car since January. When I pulled the valve cover the only obvious mods were an AMS cam cap and ARP headstuds (I also have the updated timing chain with absolutely no stretch).
Old Mar 9, 2013 | 04:28 PM
rkelley's Avatar
Since I found some sludge collection on the cam sensor (due to it being magnetic) I'm going to pull the valve cover and check the passages again in addition to changing the oil.
On another note, I just did a trans fluid change and switched to the redline cocktail, holy cheeseballs!!! It feels like someone draped my shifter in velvet. I had already installed a Torque Solution short throw shifter and TWM shifter base, underhood, and transission arm bushing, as well as a Blox 490 heavy shift knob. By far, the redline cocktail has made the best improvement. I can't wait till I hit 500 miles with it.
Old Mar 10, 2013 | 07:41 PM
rkelley's Avatar
Originally Posted by acm_evo
There is a TSB for your issue. Apparently, there is an issue where the ECU throws codes relating to chain stretch in error. You need to take the car to the dealership aniid have them use their MUT III tool to have the ECU relearn the chain learned values. After that, they will reflash the ECU with an update. I had this done several months ago, and the CEL has not come back since.
I had heard there was a tsb for the learned values and relayed that to mechanic at the dealership. He said that he reset the learned values with the MUT tool but the code still popped. He even spent about an hour on the phone with a Mitsubishi "master tech".
At this point I'm at a loss. I'm tired of babying my Evo (the ECU was locked when I got so I had to bench it to the stock 52680020 ROM). I desperately need a tune I feel like I need to get this code resolved before I can get an e-tune.
Old Mar 10, 2013 | 08:25 PM
migs647's Avatar
So the tech told you to pound sand?
Old Mar 10, 2013 | 09:09 PM
rkelley's Avatar
Yeah, pretty much said he didn't know what else to do. So now I'm at a loss as to where to go from here. Guess I'll see if a tuner will compare target vs. actual exhaust cam advance to see if it's phantom or not.
As I mentioned earlier, I disconnected the battery and had a P0011 CEL afterwards. That's gone and the P0014 is back. NEED A SOLUTION
Old Mar 11, 2013 | 07:47 AM
Thomar's Avatar
Question; the redline cocktail you refer to, is that redline mtl?
