Sponsored by:
Sponsored by: CARiD
opinions what to do when I put mods on
Old Nov 2, 2015 | 09:20 AM
DeweyD's Avatar
The car will not boost correctly as has already been mentioned. At light loads and partial throttle the ECU should be able to adjust for the mods and allow you to cruise normally. I wouldn't over think it. The real issue would come if you were driving it hard, you would likely over boost quickly and possibly run very lean. Just shift under 3K and feather the gas. No need to tow it in my opinion. Something like cams and injectors would make the car undrivable.
Old Nov 3, 2015 | 06:15 AM
EvoX267's Avatar
thanks for all of the responses. I was just over thinking it. it just sucks because it is a 3 hour drive lol.
Old Nov 3, 2015 | 07:06 AM
migs647's Avatar
+1 on installing everything minus 3 port. You'll be fine, keep your foot out of it
Old Nov 3, 2015 | 09:16 AM
SVPxTuRbO's Avatar
You can do it bro, we believe
Old Nov 3, 2015 | 02:33 PM
AngryEvo's Avatar
No way in hell you are staying out of boost on a 3 hour drive. You planning on going 50 in 5th the entire time? Lol
Old Nov 11, 2015 | 03:33 PM
nsrt4me's Avatar
You'll be fine just drive easy, don't go into boost. The car may run just a little rough, more so throw a CEL for the non-cat.
Old Nov 11, 2015 | 03:59 PM
Napalm_Enema's Avatar
Look at it this way, it's a three hour drive there, then like a 34 minute drive back.
Woo woo
Old Nov 11, 2015 | 05:35 PM
DeweyD's Avatar
Why not? I can do it.
Old Nov 12, 2015 | 01:58 AM
AngryEvo's Avatar
Good for you. You are risking damage to your car.
Old Nov 12, 2015 | 05:40 AM
MisterRegato's Avatar
youll be fine man even if you hit boost I doubt serious damage will occur
Old Nov 12, 2015 | 08:38 AM
DeweyD's Avatar
I think you are over emphasizing the risk. To cause real damage you will need to over boost or run very lean at high load, neither of which is going to occur on a leisurely paced cruise. I can drive all over the place and never trip a single psi of positive boost.
Through what mechanism, assuming he drives slow, is he going to damage his car?
AnthonyShedlock
Jan 28, 2010 07:47 PM
baddogevo
20
Sep 19, 2007 06:54 AM
backcountryGSX
Apr 17, 2006 04:22 PM
Boosted GP
14
Jan 4, 2006 03:51 AM
lancer02Josh
Lancer Troubleshooting
Mar 25, 2003 10:49 AM
