Sponsored by:
Sponsored by: CARiD
second opinions on some fluid leak? PICS included
Old Nov 23, 2015 | 02:08 PM
iKENwin's Avatar
so i discovered i was leaking some fluid indicated by my garage floor. pulled the panels and i think i found the culprit. i cant seem to see anywhere else. anyone? thoughts?
so this is where i found most of the fluid.. underneath driver side axle..
this looks like a busted seal coming out of driver side (output shaft i wanna say) axle.
this is the part oreilly's personnel and website say will replace the axel seal.. but i think this is the actual P# EVO X MN132370+ 3200A145. (i cant get unless i order) is orielly's a subtle sub? anyone?
this is the passenger side axle seal (i think) no leaks, looks fine, looks the same as the drivers side except not damaged..
side note.... where can i get more of these?
anyones opinions? should i be looking elsewhere for leaks? I CANT FIND WRITE UP ON AXLE REPLACEMENTS. I SUCK AT FORUMS AND LIFE. PLEASE HELP.
Old Nov 24, 2015 | 06:12 AM
Chef-j's Avatar
you can get more clip from dealer or check home depot. Not sure about other parts.
Old Nov 24, 2015 | 07:36 AM
iKENwin's Avatar
thank you good sir, i will look at home depot or lowes. no mitsu dealer near me unfortunatley.
Old Nov 24, 2015 | 09:06 AM
hoobastnk90's Avatar
ive seen like bags of these clips on amazon for like 10 bucks for like 50 or so .
Old Nov 24, 2015 | 11:34 AM
►EvolutionX◄'s Avatar
Call dealer and order an OE axle seal for that leak, don't get an aftermarket one, as they will typically fail more frequently than an OE. Negligible price difference as well.
Old Nov 29, 2015 | 10:21 AM
iKENwin's Avatar
I have ordered the oem part from mitsu just gotta figure which way it goes in and how to press it into the case.
EvilDSM97
Jul 16, 2016 06:10 PM
visualoddity
Mar 31, 2014 06:50 AM
flnsx
Feb 25, 2014 04:47 PM
Blacksheepdj
Lancer Troubleshooting
Mar 31, 2005 08:44 AM
