Sponsored by:
Sponsored by: CARiD
Tune with a catback and panel filter?
Old Jan 11, 2016 | 06:27 PM
ladiesman442's Avatar
I have a 2015 EVO FE I was wondering if I threw a catback exhaust and a drop in a new panel filter if it would require a tune, or if it's highly recommended ?
Old Jan 11, 2016 | 06:55 PM
redlightrunner's Avatar
you honestly don't need a tune with that. Kozmic claims 10-15hp gains just off of the panel filter.
Old Jan 11, 2016 | 08:18 PM
Thomar's Avatar
Nope, no tune needed. But no tune, no gains.
Old Jan 11, 2016 | 08:25 PM
Napalm_Enema's Avatar
You will see a bit of gain from a drop in filter, I'd recommend the Cosworth since you don't have to oil it. Oiled intakes are sometimes more trouble than they are worth. If you add too much oil you can foul up your MAF sensor.
Old Jan 11, 2016 | 08:33 PM
Thomar's Avatar
Nope, no gains. A bit leaner maybe. Need to adjust ecu tuning to see any gains on a turbo.
Old Jan 12, 2016 | 05:01 AM
Incorrect I had a dyno done on my car with just a panel filter and it was 10-15hp more than when it was stock . I didn't expect gains, but they were there and the powerband was much smoother. Just speaking from experience, not someone that is wishfully thinking!
Old Jan 12, 2016 | 10:30 AM
PriusRepellent's Avatar
I have the cosworth drop in filter, and I have to agree with the above. No tune needed
Old Feb 24, 2016 | 04:06 AM
CaptainCrunch's Avatar
Thanks for this thread! Wanted to go catback, no test pipe, and wasn't certain about needing a tune right now. Thank you all!
Old Feb 24, 2016 | 05:49 AM
bdean531's Avatar
Quick question...
If I'm not mistaken, adding a Cosworth drop in filter will make the car run a bit more lean, which is typically fine since Evos run a bit rich from the factory.. is this correct?
If so, people have found that the factory FE tune is already a bit lean (maybe not to a dangerous degree like some claimed, but a bit lean nonetheless), so could there be any potential issues from adding the filter without a tune?
Old Feb 24, 2016 | 06:04 AM
Robevo RS's Avatar
you don't need a tune, if changes only being made after the catalytic converter or/ and drop in filter.
Old Feb 24, 2016 | 06:26 AM
Originally Posted by bdean531
Quick question...
I noticed zero ill effects after running one for a couple months before I got full bolt ons.
Old Feb 24, 2016 | 09:27 AM
splattj's Avatar
Any gains you see would be from your car running leaner on the super-rich/safe factory tune. That said, it's not a big enough change to see big gains or run into any issues either.
If you're trying to stay away from big mods, a panel filter/cat back/and boost solenoid plus a tune gets you a pretty good bump in power.
pistonless
Mar 15, 2010 07:15 AM
98autogstspyder
Jul 26, 2008 06:25 PM
urBan_dK
Apr 16, 2008 07:45 AM
