Sponsored by:
Sponsored by: CARiD
Low issues?
Old Mar 29, 2016 | 01:22 AM
ohYouEvo's Avatar
Low issues?
Hey guys!
So i recently bought some Fortune coils. I lowered it and put some rear camber arms to have the aligment be on point. issue is that is not 100% good cause we know by lowering we will still have some camber. Now my issue is that every time I start to pick up speed by 3000 eps starts to shake!! so i toke it to the shop to redo the alignment and so they did and they said that i would need to buy the toe arms to stop the shake, but now they are also saying that thats one of the issues when lowering the car, because the axels are not in the stock high making them vibrate when picking up speed fast and thats when the car starts to shake.Has any one encounter this issue??
Old Mar 29, 2016 | 06:49 AM
hoobastnk90's Avatar
Just out of curiosity do you have aftermarket wheels?
Old Mar 29, 2016 | 07:38 AM
ohYouEvo's Avatar
Yeah. I have some 19's te37 by 8.5
Old Mar 29, 2016 | 07:58 AM
LetsGetThisDone's Avatar
Did you install the wheels with hub centric rings?
How much did you lower the car? A 2-2.5" drop won't cause any issue with the axles. If you put it on the ground, that might create some issues though..
Old Mar 29, 2016 | 08:38 AM
ohYouEvo's Avatar
So I don't think it has the hub centric rings since I purchase the car with does rims.
I drop the car about 3"
Old Mar 29, 2016 | 09:02 AM
My guess would be the lack of hub centric rings. Try raising it up a little and see if that helps and then you will know for sure.
Old Mar 29, 2016 | 02:47 PM
AngryEvo's Avatar
Come on now you are slammed admit it. Need rings and raise it.
Old Mar 29, 2016 | 08:43 PM
ohYouEvo's Avatar
i try not to go that low, but i am some what haha.
does anyone have any 18's 10.5 set of wheels that dont rub in the rear or dont have any issues?
Old Mar 30, 2016 | 11:40 AM
afnan740's Avatar
I am having the exact same issue, it only shakes when i go wot in any gear. Lowered on Ohlins R&T.
Old Mar 30, 2016 | 02:13 PM
TxFAkuma's Avatar
It is NOT the hub rings. It can be.. but i doubt it. Because i had this problem with 2 of my Evos. You need better weights on the wheels. I forgot what the weights are called that i have on both cars now but.. it fixed my problems completely at high speeds and low speeds. Go to a discount tire or tires plus or wherever and they will install sticky metal weight stripes.
Old Mar 31, 2016 | 06:49 AM
I think most places use the stick on weights the only other type of balancing you can do is called road force balancing which is the better method that can be used, generally costs a bit more and not as many shops have that. Also there is a good chance its the hub centric rings I had a regular balance done on my stock wheels when I had my track tires put on them and they are perfectly smooth, but my after market ones have the same vibration and I also skipped the hub centric rings. And they used the metal stick on weights, so I wouldn't just completely rule that out.
Old Mar 31, 2016 | 07:58 AM
.M.'s Avatar
.M.
Did the shop check to see if you have the rings (couple bucks) and if the wheels are balanced correctly? I'd start with that first. Raise it up a bit and see if it helps.
Old Mar 31, 2016 | 09:40 AM
afnan740's Avatar
I got everything checked out. Wheels balanced twice, hub rings for aftermarket wheels in place and rotated to see if vibration would move around and nothing.
Last i will do is to raise the height up to see if it goes away. I am currently a finger and a half all around.
Old Mar 31, 2016 | 10:38 AM
ohYouEvo's Avatar
Low issues..
Could it be maybe because I only have a 8mm spacer up front and rear I have a 16mm lol. I think that might be the issue huh? 🤔
LancerShop.com
Lancer Vendor Classifieds
Oct 27, 2016 06:25 PM
chad99evo
Apr 1, 2012 08:10 PM
speedfreak24
Feb 15, 2010 08:35 PM
mindoftw
Jun 10, 2009 06:17 PM
Show Off
Feb 25, 2008 10:52 AM
