Sponsored by:
Sponsored by: CARiD
Please clarify this cant get a straight answer anywhere
Old Apr 1, 2016 | 01:24 PM
RATEDX's Avatar
Exclamation Please clarify this cant get a straight answer anywhere
thinking about going with the redline cocktail, im assuming the 2quarts MTL and 1 quart MT90 make the 3qt total, but the service manual calls for 2.6 quarts. How do you adjust the mix of the two? How does everyone feel about this cocktail, I live in NYC so it gets pretty cold and dont do any tracking. Opinions?
ALSO: just read 8 pages of this and my head is spinning as there isnt a straight answer to anything.
http://www.evoxforums.com/forums/sho...t=36393&page=8
DO YOU HAVE TO BLEED THE SYSTEM AFTER YOU PUT THE DIAMOND ATF SPIII IN? I know the xfer case and part of the rear diff take the DIAQUEEN LSD, Im talking about the SECOND PART of the rear diff that takes the ATF SP III ( service manual is calling it the TORQUE TRANSFER MECHANISM PART)
SOMEONE PLEASE CLARIFY THIS IM BEGGING YOU
Old Apr 1, 2016 | 02:08 PM
hydro334's Avatar
1 MTL, 1 MT90, then MTL for the rest.
Old Apr 1, 2016 | 03:09 PM
hoobastnk90's Avatar
Or just save yourself a lot of time and order MT-85 and call it a day. Works better IMO
Old Apr 1, 2016 | 03:18 PM
.M.'s Avatar
.M.
^That's what I did. No complaints here. Works great.
Old Apr 1, 2016 | 05:12 PM
RATEDX's Avatar
can anyone clarify the whole bleeding thing? Need a straight answer before I do the fluid change
Old Apr 1, 2016 | 06:01 PM
LetsGetThisDone's Avatar
The ATF you change on the rear diff is just a drain and fill, no bleeding. You're only draining the lubricant for the clutch pack. You're not draining the pressurized AYC system.
V1RGINEVO9
Feb 24, 2011 06:36 PM
bryanole27
May 4, 2009 11:20 AM
evolancer04
Sep 2, 2008 04:03 AM
lemacfar
Sep 27, 2005 02:41 PM
