front fender pulled/rolled rpf1 wheels 275/35/18
Here are some pictures from this weekend.
Pulling/rolling front fenders was pretty scary cause it is aluminum but it worked out pretty well. Still working on it. Still needs a alignment.
Rolling did not go so well, just ended up pulling them more then anything
wheel and tire specs
Wheels are rpf1 18x9.5 Tires are Toyo r888 tires 275/35/18
Before
After
Before
After
and because no one else has posted anything at all about touching the front fenders so i wanted to see if i could do it without paint cracking.
everyone i talked to said aluminum fenders suck so much so i wanted to prove them wrong with not only doing this but also in the look and performance
final ride height is not done yet just prepping for it. wanted to show ppl that the front fenders can be pulled. It is still sitting high i will take pictures and update when everything is done it has no motor in it right now so can not do a alignment or set ride height yet
Well,
He hasn't listed the offset yet, but I highly doubt any work on the front fenders was necessary. Running 275/35 tires usually will rub slightly on the inner fender liners, but doesn't scrap the fenders themselves.
Seems more he did it just to do it? Maybe in anticipation it would rub without asking on the forums or testing it. Either way, it's not an issue.
Looks good to me though, and if he's happy with it then props to him!
IAmADirtDude
13
Jun 8, 2011 11:53 AM
