Rolled and pulled fenders!
Old Jun 20, 2011 | 05:13 PM
YoitsEVOSAL's Avatar
So I'm guna do my rear fenders maybe on Wednesday! Reason being I jus got brand new tires on Tuesday now the outer walls r rubbing n My fenders are eating away my new tires!! Not good!!! So I wana see sum pikz of ur fenders rolled and pulled! Jus so I kan get a feel for em! My tire size is 265/35/18 93W! If that helps any! Also is ther any downside to having them rolled or pulled?? Thanx! Hope to see some pikz on here!
Old Jun 20, 2011 | 05:19 PM
JEP's Avatar
JEP
I wouldn't think with correct offset rims you should be rubbing with that tire size.
Old Jun 20, 2011 | 05:35 PM
My wheels are 18x9 I believe? +17
Old Jun 20, 2011 | 05:37 PM
f1av8trfan's Avatar
Is the car lowered...springs, coilovers?
Old Jun 20, 2011 | 05:48 PM
tsunari's Avatar
Yeah, with the proper offset, you might just need the lip rolled (no pulling needed)
Old Jun 20, 2011 | 06:02 PM
Yea car is lowered on jus eibach springs...
Old Jun 20, 2011 | 06:08 PM
Nzo's Avatar
Nzo
Unless you trying to make a lowrider out of your X you should just need a rear fender roll if that
Old Jun 20, 2011 | 06:17 PM
Lol!! Lowrider x!! Might b the first!! Hahaha naw!! The guy I spine 2 said I might need a fender roll n pull...I thought all I needed was a roll also! I'll c Wat happens wen I meet up wit him
Old Jun 21, 2011 | 09:06 AM
Jor-El's Avatar
I'm running 18 x 9.5 with 265/35/18 and dropped in eibachs, and my fenders are neither rolled nor pulled. No rubbing
Old Jun 21, 2011 | 09:50 AM
What the hell!!?!? Really?? Then why does mine rub?? What brand tire do u have?? Cause when I had my dunlops it wouldn't run either but with my bfg's it does
Old Jun 21, 2011 | 10:01 AM
ugakirk's Avatar
The new tires might be a little wider. Can't u add just a little more camper to the rear to get it to not rub..
Old Jun 21, 2011 | 10:39 AM
harpreet1012's Avatar
whats your offset?
i have 18x10.5 +15, 285/35/18 and i did a full roll and a slight pull and im not rubbing at all...
Old Jun 21, 2011 | 02:09 PM
If I add more camber wouldn't my tires go out faster?? That's the only bad part about that
Originally Posted by harpreet1012
whats your offset?
18x9 I believe...+17 offset
Old Jun 21, 2011 | 02:12 PM
saulbyu's Avatar
18x10 +25 offset, Invo 275x35x18 and it rubbed so I rolled the rear fenders, fronts are fine. I used to have Nitto NT05s on 265x35x18 and never had any rubbing issues by the way.
