Sponsored by:
Sponsored by: CARiD
Center console swap?
Old Apr 29, 2016 | 08:08 PM
20redfire03's Avatar
What all is needed to swap from the center console with the 2 push button door/covers in front the shifter (ash tray/power outlet) to the center console without the doors where it appears more opened up. I would also like to change the section behind the shifter to get rid of the door covering the cup holders. If the swap is possible will I run into any issues with my heated seat buttons? I'm assuming the armpad is swap able between console designs as well?
When I ask what parts are needed are there specific part numbers I should be looking for?
Thanks
Old Apr 30, 2016 | 06:51 AM
migs647's Avatar
I believe the parts you need:
[ 23 ] BODY HARDWARE / CONSOLE / CENTER CONSOLE / Cup holder
Part Number: 8041A013XA
cup holder
[ 19 ] BODY HARDWARE / INSTRUMENT PANEL / INSTRUMENT PANEL COMPONENTS / Compartment box
Part Number: 8010A071XA
compartment box w/o navigation sys
If it helps, I went to mitsubishiparts.net for their diagrams. https://mitsubishiparts.net/parts/20...iagram=viewAll
Attached Thumbnails Center console swap?-6266310.gif   Center console swap?-6266335.gif
Old May 3, 2016 | 12:41 PM
Veronica's Avatar
Never mind. I re-read OP.
Old May 3, 2016 | 02:20 PM
TurboTJ's Avatar
Thanks
Your heated seats switches will swap right over to the open cup holder console. I did this when swapping my MR Recaro's into my FE. You just need to knock out the blank panel put in their place.
Old May 5, 2016 | 10:42 AM
Lytec's Avatar
I am not sure how the back-most half of the center console would affect your heated-seat buttons as mine is a 2008 GSR withou that option... But, I would totally swap the shifter/compartment piece! I've been wanting the doors instead of the open bottom compartment. Is yours that glossy black? Mine is flat black plastic no finish to this part.
Old May 5, 2016 | 12:04 PM
The doors on my console are glossy, it's close to black but to me at times looks blue. It matches the long divider piece on the dash and doors.
Old May 20, 2016 | 05:07 PM
909*DC5's Avatar
Does Anyone have pictures of the difference between the 2?
Old May 28, 2016 | 06:32 AM
So I have been looking for the center console parts off and on and believe I might have found a solution but not 100% sure if my idea will work.
I know either way I will need the picture of the climate control surround and cubby (img 0318). But can I buy the 2 separate pieces (lidless cupholder center section (0320) and shifter surround (0319)) or would I need the center console piece (0317)? Looking at other pictures online of for sale consoles the center console appears modular in a sense where pieces can be swap from one to the other but I don't know for sure, it would make sense from a manufacturing stand point and not having to have multiple center console part numbers.
And for the member who asked about the differences image 0321 is a poor picture of the other style of console which is also the style I currently have.
Attached Thumbnails Center console swap?-img_0318.png   Center console swap?-img_0317.png   Center console swap?-img_0319.png   Center console swap?-img_0320.png   Center console swap?-img_0321.png
xteekayx
May 30, 2017 10:22 AM
Sheasta
For Sale - Part Outs
Nov 12, 2015 02:50 PM
Cyrax91
12
Jun 12, 2015 06:39 AM
doncarbone
12
Dec 9, 2012 06:32 PM
42revoincali
11
Jul 13, 2010 11:52 PM
