high pitch wine
high pitch wine
I just installed an ams intake, intercooler,upper and lower piping with the tial BOV. I changed the map on the car to include the new parts. These are the only aftermarket parts I have on the car. Now at around 4000 rpm on up I get a high pitch wine that I can only describe as air being released from the end of a ballon. It's not the turbo spooling or the BOV. I have double and triple checked to make.sure all the hoses are on and tight which they are.
Any suggestions on what it might be?
I think you need a proper tune on the car, personally. Even if you're not close to someone there are great e-tuners out there.
I live in moco. I didn't think it was leaking boost since the boost levels have been the usual. I haven't done any hard pulls though. I do plan on getting it tuned by a shop as soon as I put on the turbo back exhaust. Just used the Cobb tune to make it drivable.
Can you make the sound in the driveway by just revving to 4K?
If so - carefully listen at the turbo (touch it with a long socket extension to your ear) and then the accessories for a bad bearing. Be careful of the spinning bits, eh!
Also, do a boost leak test. Just hitting your target boost does not rule out a small leak.
Maybe half a turn on a clamp (I know you checked yours, this is my example) fixed a noisy boost leak on mine... It can be a real small leak.
Mine does it with the cobb attached or not. I will not make the noise just revin it only under load. I have noticed it also doesn't make the noise until the boost get to 10+ pounds. I have went though and redone all the clamps and it is still making the noise. any other suggestion?
Pro-tunes can be good, but they aren't the end all be all, and cobb OTS tunes is definitely the way to go if you are still in the process of purchasing car mods.
Also,
Have the same setup and same noise. I'm pretty sure it's a boost leak issue, been meaning to get on testing that. I'll let you know if I do figure it out.
Same situation too. Only under load and when boost gets to above 15 or so psi in the 4000+ rpm range.
Certainly sounds like a boost leak to me. I once forgot to tighten the UICP after working under the hood and 5 minutes into driving the clamp popped off which gave the sound you're describing.
