Sponsored by:
Sponsored by: CARiD
Stock Clutch Failed at 3400 miles
Old Nov 9, 2016 | 08:29 AM
.M.'s Avatar
.M.
No reason to take it to the dealer. They're not going to cover it. I mean... unless you want them to the labor for the new clutch.
Old Nov 9, 2016 | 10:55 AM
nvmaddog's Avatar
Originally Posted by A872B
I was hoping for 3.9 but I'm at 4 flat
Rolling down hill?
No offense but those numbers are hard to imagine with only exhaust and intake, that is a full second off of stock pro drivers published times.
Anyway back to the matter at hand, you can probably get some of it covered through the dealer if you put it back to stock, they are still going to argue that the clutch is a wear item, but at the end of the day I bet you could at least get the parts cost covered then pay the labor.
Old Nov 9, 2016 | 12:21 PM
Napalm_Enema's Avatar
I always launched my MR. obviously it's not the same but still. If these cars were not made to launch then why is there launch control? I don't drive my cars like a jackass. I thought the clutch would have been able to handle it since I thought they're good for around 400hp. I only launched the evo because I was playing around with the Cobb ap to see if I can get my 0-60s down. I was hoping for 3.9 but I'm at 4 flat
The MR has built in launch control, so that's not so bad to launch in it. The GSR can lead to big expensive repairs if you don't launch it 'just right'.
Old Nov 9, 2016 | 12:28 PM
A872B's Avatar
Originally Posted by nvmaddog
Rolling down hill?
i just do first gear, full throttle (revs hang around 4900rpm I think) and I go from there. It was a slight decline but still, car and driver rated the final edition at 4.3 0-60. It's not insane that I'm pushing a lot more power to reach 4.1 or even 4.0 dead
Old Nov 9, 2016 | 12:55 PM
nismo n9ne's Avatar
It's considered a wearable part. Unless you can find a reason other than beating on it for it to fail, they won't touch it. I suggest getting a twin disk and starting to save money for the other broken parts from launching. I'm not saying there is anything wrong with it, cars were built for that purpose, But you gotta pay to play.
Cheers
Old Nov 9, 2016 | 12:58 PM
A872B's Avatar
Rolling down hill?
Cheers
okay it's safe to say I won't launch it anymore. Even with an upgraded clutch. Do you think there's anything wrong with the transfer case?
Old Nov 9, 2016 | 01:14 PM
nismo n9ne's Avatar
Is it making any noise?
Old Nov 9, 2016 | 01:15 PM
A872B's Avatar
Nope, everything else is golden.. for now
Old Nov 9, 2016 | 01:29 PM
t3am 83rd's Avatar
...If these cars were not made to launch then why is there launch control?...
I always wondered that...anyone have an answer?
Old Nov 9, 2016 | 01:47 PM
It is probably fine, as the clutch took all the punishment. If you had removed your clutch pill and then screwed up a launch you would have a higher likelihood of nuking the transfer case. Just replace the clutch and then see if it drives normally. If so, just enjoy but this is more of an autocross car than a 1/4 mile car imo.
Old Nov 9, 2016 | 02:12 PM
IMO the MR is meant to be launched, but they took steps to make the GSR less launch friendly. (clutch pill) I don't believe launch control exists in stock form for the GSR correct me if wrong though.
Old Nov 10, 2016 | 05:15 PM
moladin's Avatar
GSR has launch control:
http://www.evoxforums.com/forums/sho...d.php?t=288081
Old Nov 11, 2016 | 07:16 AM
Ev0ikon's Avatar
Does the car still have the slave cyl pill?
Consider yourself lucky because the clutch is easier/cheaper to replace. I can't see so I can't tell how well you drive/release the clutch.
Old Nov 11, 2016 | 08:22 AM
Originally Posted by moladin
I think it used to have it, but not in later models. I want to say it was removed around 2011/2012.
Old Nov 11, 2016 | 10:17 AM
LetsGetThisDone's Avatar
The clutch pill does not make the car unfriendly to being launched. Even with the pill in there, you can side step the clutch and shock the f#ck out of the drivetrain. That pill makes the car easier to drive normally by making clutch engagement easier to modulate when shifting and taking off normally.
The Evo can launch, its just pretty well known you're going to wear clutches out when doing. Even if you have an MR, you're going to experience premature clutch wear with repeatedly launching the car.
The GSR has a two step (stationary) rev limiter from the factory, its at like 5000rpm I think.
The drivetrain can handle proper launching (proper amount of clutch slippage to avoid shocking the driveline, and avoiding wheel hop are the main concerns). In the X, you'll explode the rear diff in a higher power car, but that is solved with doing the ct9a rear diff swap.
Launching is still hard on parts, no matter what car you have. So expected repeated launch to decrease the life of certain parts. 1st gear, transmission input shaft bearings, clutch, and even the diff and tcase. But if you're doing it right, you're not going to have catastrophic failures every 3500 miles.
