Sponsored by:
Sponsored by: CARiD
Recaros from wrecked car
Old Dec 23, 2016 | 11:05 AM
c08's Avatar
c08
I was just wondering what the risks would be of using a set of Recaro seats that came out of a wrecked car (but seat airbags did not deploy). If something related to the airbag was damaged or knocked out of place from the impact, would it always be detected when all the wiring is plugged in (and cause airbag light)? Anything else structurally that could be damaged and compromise safety without being immediately obvious when looking at them?
I am just curious since I've seen sets from wrecked cars for sale, and other sets where it is not clear what car they came out of.
Old Dec 23, 2016 | 02:50 PM
wave5000's Avatar
Hi, I have Recaro set from a wrecked 2012 MR in my 2015 GSR. The driver side airbag is blown but I stitched it back up with nylon thread. Do not plug the connectors but use a resistor instead no faults came up. The driver side is plug and play but you need the OE weight sensors etc. no faults came up on my install and the dealer did not say anything when I went for service.
Old Dec 23, 2016 | 02:54 PM
wave5000's Avatar
These are from wrecked 2012 MR in my 2015 GSR. The passenger is the blown side but stitched back up with nylon thread. Do not plug the connectors but use resistors instead no fault came up in this install.
Old Dec 23, 2016 | 02:57 PM
c08's Avatar
c08
Thanks. I see that it is possible, but I was more wondering if there are any safety concerns with using seats from a wrecked car (even if the seat airbags weren't deployed).
Old Dec 23, 2016 | 04:32 PM
NinjaX's Avatar
No risk, if they were not deploy, you should be fine and in case of an accident they should deploy.
Old Dec 24, 2016 | 05:54 AM
CaptainCrunch's Avatar
I need Recaros in my life.
Old Dec 24, 2016 | 06:35 AM
NinjaX's Avatar
Old Dec 25, 2016 | 08:44 AM
Evo302011's Avatar
If the airbags never deployed in the seats, you'll be fine.
Old Dec 26, 2016 | 07:23 AM
Greyfax's Avatar
Can Recaro's be put in a Final Edition, and if so, what kind of modifications would need to be made, if any?
Old Dec 26, 2016 | 07:58 AM
NinjaX's Avatar
There is nothing special about the US FE, i did it on my 2015 and is just a swap of the weight sensor and seat bealt from the cheap lancer seats. Other than thet is bolt on, they just did not install the recaro on the 2015 or FE due to US regulations.
Old Dec 26, 2016 | 08:43 PM
4b11slayer's Avatar
If the srs module did not deploy the air bags or the seat belt pre tensioner then you should be a ok.
Old Mar 31, 2017 | 06:34 PM
Cirielmd's Avatar
so do you use the OE weight sensors in the 2015 or do you need the ones the recaros came with?
Old Mar 31, 2017 | 07:01 PM
c08's Avatar
c08
I think you use the sensors that came with the car. See "INSTALLING DIFFERENT OEM FRONT SEATS" on https://www.evolutionm.net/forums/ev...ult-codes.html
Old Mar 31, 2017 | 07:05 PM
moparfan's Avatar
Anyone ever go ghetto and just change only the driver's seat to Recaro?
Old Mar 31, 2017 | 07:40 PM
DBomb117's Avatar
LMAO, I considered it for like .25 seconds.
