Sponsored by:
Sponsored by: CARiD
1st time getting evo tune
Old Jan 21, 2017 | 10:07 PM
joonvang's Avatar
Hello,
im planning on getting my evo x sitting at about 10,000 miles tune with the following bolt on (grimmspeed ebcs, works drop in filter, ultimate racing upper intercooler pipe, ultimate racing Cat back exhaust & HFC). How does the tuning process work? Am I suppose to tell my tuner all the mods done to the car? I've heard story about engine blowing up bc the grimmspeed ebcs wasn't tune properly. Is the tuner (experience with evo) supposed to know what to tune the car to if I tell them my mods? Is a grimmspeed ebcs even needed at my current level of mod + tune? Your answers are much appreciated
thanks.
Old Jan 22, 2017 | 12:54 AM
Olegator's Avatar
Technically the tuner might already have a map that will fit to your modification list, therefore giving him more time to do some minor adjustments.
In choosing the tuner reputation and reviews are everything. Choose carefully and do your research.
Ebcs is supposed to first, make it easier to tune (standardized ecu to wastegate interface), as well as smooth out the boost curve.
Old Jan 22, 2017 | 09:27 AM
jakgal04's Avatar
They'll usually ask you what kind of mods you have, and then they'll start off with a base map. Something very conservative, but a safe start that the tuner can then refine to make the most out of your cars potential.
Old Jan 24, 2017 | 09:41 AM
UxC's Avatar
UxC
Veteran: Army
If you want to spend less on a tune, think about getting an Etune. Beeble has been working with me to get my Evo X tuned and it's been a blast. However, you have to know wiring and have a wideband afr to get a more accurate tune. Grimmspeeds are great at any level of tune, because the stock boost solenoid isn't that great.
Old Jan 25, 2017 | 03:14 PM
TxFAkuma's Avatar
Originally Posted by joonvang
Hello,
thanks.
Basically, It takes 3-4 hours. Let them know your mods. Tell them to INSTALL YOUR EBCS THERE. Again, do not install this and go there. Have the tuner install it.. it takes 10min. Then, grab your cellphone and video tape some awesome pulls AFTER he does some short ones.
P.S - Go to DB Performance.
Old Jan 29, 2017 | 08:09 PM
brentraby's Avatar
Veteran: Army
All of the mods that you have are going to play a part in the way that the car is tuned so whoever tunes it should want to know what you have on the car. I used the OTS tunes used with the accessport at first, then switched to open source. Cobb recommends certain mods before you use their OTS tunes and the guy I used to do my road tune wanted to know what I had before he tuned it. Mods and tunes go hand in hand so take note of all of the replies that you get and make a well informed decision about who you choose to do the tuning.
Old Jan 29, 2017 | 11:11 PM
kaj's Avatar
kaj
ECU boost control > *
xrvc
May 17, 2017 11:17 AM
Konakev
Oct 30, 2016 01:20 PM
diego88
Apr 22, 2013 07:50 PM
920rs
Jun 15, 2009 06:30 PM
Evo_Dream
Jun 9, 2005 10:03 AM
