How to 400 whp with pump gas?
I would go:
Intake, turbo back exhaust, S2 cams, 1000cc injectors, fuel pump & Blouch 2.0XTR (same as old CBRD BBK full if you want to look up dyno charts)
http://www.bptstore.com/Evolution-X-...XTR_p_145.html
Also get a larger fmic if you plan on doing extended pulls.
On an 8, a 9 or a X? Because every time I ping Aaron for cam selection on a X, if we're shooting for <500whp, he recommends GSC S1's to me. So pretty much any application where a stock frame turbo is going to be used on a stock motor.
The write up was for 9. Maybe he changed his opinion in regards to the X. Here is the thread I was referring to. https://www.evolutionm.net/forums/ev...tle-turbo.html
The 4b11 is a completely different beast from the 4g63. Data from the 4g63 does not at all correlate to the 4b11. Bore/stroke are completely different, and the cylinder head is WAY different.
Sure, but S2's should still put down more up top. If OP goes go with the smaller cam, he might need a bigger turbo (than the 2.0xtr) to hit 400whp.
I guess I feel like S1's are such a slight increase in power that the money could be better spent elsewhere.
The MHI18k will make over 400 on 92 octane pump with stock cams on a GSR.
https://www.evolutionm.net/forums/ev...30whp-gsr.html
On a X, the stock frame turbo's are done before S2's are needed. Especially with the tiny stock exhaust ports.
Depeends on the pump gas though. 91 octane would put it closer to 400, and running a recirculated DP would further lower power a bit more. A set of S1's would more than make up for it. I put them in a friends stock turbo X, he gained 30whp on ACN91. Up to 360whp from 330whp. Only change was cams.
How much of a difference does a recirculated vs dumped downpipe make on these cars? I'm used to a platform where it didn't do much, but I have heard multiple times that on the Evo it does.
