Sponsored by:
Sponsored by: CARiD
Recently bought an Evo X, first mods??
Old Jun 23, 2017 | 12:22 PM
BStalzer12's Avatar
Intake
Old Jun 26, 2017 | 08:04 AM
redlightrunner's Avatar
Take the car the espec or ivey since youre out in NY and located right near them. They will get you taken care of.
Old Jun 26, 2017 | 12:23 PM
Meez's Avatar
Originally Posted by kevo10
First I would change the the transfer case and diff fluid if you don't know when it was last done.
Intake, full exhaust, and tune for power to start off. Then coilovers and a rear sway bar for handling. Also, get good tires and brake pads when you replace them. No point in spending thousands on upgrades if you have crappy tires/brakes.
For looks do whatever you like; wheels would be where I'd start.
This.
Old Jun 29, 2017 | 01:51 PM
Schwingy's Avatar
Not a mod but I would definitely check the fuel pump relay to make sure they are the newest version!
Old Jun 29, 2017 | 08:18 PM
AF13_Evo's Avatar
Veteran: Air Force
Originally Posted by donny_utah
Second that motion for all new fluids change if unknown when the last service interval was. Especially your SST.
What are all the fluids to change specifically?
Old Jun 29, 2017 | 08:58 PM
Roen's Avatar
Diaqueen LSD for the Transfer Case and the Rear Diff
Diamond ATF for the Rear Diff AYC fluid
SSTF-1 for the SST
Redline D4 ATF for the ACD Pump in the rear of the car
Mobil 1 0W40 Engine Oil
Prestone DOT 4 or Better Brake Fluid
50% Prestone / 50% Distilled Water for Coolant
Top Tier 93 Gas
Redline Power Steering Fluid for Power Steering
I think that's everything.
Old Jun 29, 2017 | 09:03 PM
Roen's Avatar
Originally Posted by EVOXLI
Hello everyone! Recently bought a 2012 Evo X MR w/ 36,XXX miles in white! I'm new to this platform and I'm excited to start building this car. The car is 100% stock and I have a few ideas in mind but I would still like to get other people's opinions on what are good first mods. It can be performance or aesthetic mods. Any ideas are welcome, Thanks guys!!
SST?
Change the fluid with SSTF-1 and a new paper filter.
Honestly, if you're planning on keeping the car for awhile:
3 Cans of SSTF-1
Paper Filter (can get cheap from Kozmic)
Dodson Heated Sump (Also from Kozmic)
CBRD Radiator (If you get the heated sump)
Radiator Hoses if you choose to
1 Gal Prestone Coolant Concentrate
1 Gal Distilled Water
5 Qt. Mobil 1 0W40
Purolator PL14459 Oil Filter
That's not a bad start.
You don't really need the Heated Sump if you're going to only street drive the car. However, if you do, make sure the car has been moving at load for at least 10-15 minutes before you go WOT at all. Otherwise, you run the risk of the transmission not being warm enough.
Old Jul 4, 2017 | 04:58 PM
Jhaze71's Avatar
Is a full catback going to really gain any power?
Old Jul 5, 2017 | 08:31 PM
gerikivan's Avatar
catback and remove spare tire lol. that should save u atleast 70lbs
Last edited by gerikivan; Jul 5, 2017 at 08:36 PM. Reason: didnt know it was a mr lol
Old Aug 29, 2017 | 09:10 AM
TWM Performance's Avatar
Full Replacement Short Shifter and a weighted Shift Knob
https://goo.gl/TxJBrV
Old Aug 29, 2017 | 04:07 PM
Lightsaber's Avatar
Whoa!! That is quite amazing. One shortcoming with the stock plastic shifter is that it's not the most reliable. Especially when you consider Evo X's shifts are so rough and heavy, I'm worried that it might not last long.
What advantages does the TWM shifter have over the stock plastic one?
By the way, I do have the TWM short shifter installed and thoroughly enjoyed it great shifts in the past 3 years.
salahuddin10
Jan 10, 2013 03:41 AM
stlthevo
Mar 9, 2006 01:22 PM
Tsurara
Northeast Region
Jan 5, 2006 11:26 AM
Fourgig
West Region
Feb 4, 2005 08:11 AM
Ragnarok
13
Jul 13, 2004 11:27 PM
