Sponsored by:
Sponsored by: CARiD
Help 22 + fault codes :/
Old Jul 2, 2017 | 02:15 PM
Vegeta_Ra's Avatar
Hey everyone i have 22 to 27 fault codes that only show up after 100+ kms of driving. They don't effect the performance or idle of the car, not sure why they come up
If anyone has gotten them before please chime in
Used motor just recently put in
Evo X 20 swap
AMS Intake
3 inch turbo back( ur dp, depo hfc, magnaflow cb.
Grimmspeed ebcs
X bpv
Stock injectors
Stock fuel pump
X ic( injen uicp)
Aem failsafe wideband/boost gauge
Old Jul 2, 2017 | 02:49 PM
4b11slayer's Avatar
Golly. Since you have network codes id think a wrong ecu was used.
Most of those codes usually have performance issues.
Old Jul 2, 2017 | 04:51 PM
Vegeta_Ra's Avatar
It's a stock ecu
My car is 2010
Engine put in was an 09
But same engine harness for my 2010
Timing chain off my 2010 was used because the 09 is v1.
The tune I have on right now was flashed via tephra mod v1.
So I'm at a loss as to why they are popping up. And a majority of them are emission codes
Old Jul 3, 2017 | 04:39 PM
Vegeta_Ra's Avatar
Anyone have any insight? As to what would cause these codes
Old Jul 4, 2017 | 12:21 PM
splattj's Avatar
Check all your grounds. It sounds like you might be missing an engine-to-chassis ground somewhere.
Old Jul 10, 2017 | 07:45 AM
Vegeta_Ra's Avatar
all grounds look connected
Old Jul 10, 2017 | 10:08 AM
LetsGetThisDone's Avatar
As was stated, you have CAN network codes. ECU is likely smoked.
gavi101
Jun 24, 2010 07:52 PM
stig's_mentor
May 31, 2007 06:57 AM
