Sponsored by:
Sponsored by: CARiD
Electrical issues??
Old Jul 5, 2017 | 01:38 PM
Tarry Harper's Avatar
Veteran: Army
Electrical issues?? SOLVED
I'm curious if anyone else has experienced this. At first it seemed to happen occasionally when I hit a bump but now it is just at random times. I will get a random warning chime and either "service engine required", "brake system service required", or "abs service required" on the display. The radio will turn off and back on again and sometimes the car seems to stall.
Any ideas?
::UPDATE::
Now, the gauges and the stereo shut off while driving yet the car still runs fine and I have to jump start it to get it to start...
Old Jul 5, 2017 | 03:29 PM
LetsGetThisDone's Avatar
Check all the fusible links on the power post in the engine bay.
Old Jul 5, 2017 | 04:14 PM
4b11slayer's Avatar
Look for corrosion on main harness connectors.
Also check to make sure all your grounds are good.
Could also be a can network issue assuming you have a 2015 evo x .
If 1 module has a can network issue it usualyy brings down other modules on that can bus. I.e c can. B can
Old Jul 6, 2017 | 12:18 PM
moparfan's Avatar
The brake service and abs light would flash on and off if I braked or cornered aggressively when my clutch line was leaking. It would uncovered the level sensor I guess?
I would checked your main ground first.
Old Jul 6, 2017 | 04:06 PM
4G63_EVO's Avatar
have your alternator tested
Old Jul 6, 2017 | 05:46 PM
Veteran: Army
Well, I feel like a noob now. Apparently, the dealership would disconnect the battery while it was parked and they didn't tighten them back down. Problem solved.
Old Jul 6, 2017 | 07:40 PM
4G63_EVO's Avatar
Oh wow! Glad you resolved this
TJSAP00
Jul 26, 2011 02:08 PM
Nasty2004
Lancer Troubleshooting
Jul 11, 2010 04:43 PM
Daskid
May 16, 2009 11:44 AM
Peteypab2133
Feb 3, 2007 06:13 PM
jtc
Mar 11, 2004 08:02 AM
