Evo X MR or GSR?
the sst is a beautiful piece of technology. Its faster (the trans) period then a 5/6 speed in pretty much all things. If money is not a concern go with the SST and upgrade it appropriately for your power levels. If you are working on a budget though the 5 speed will survive a lot longer without as much investment. Unless you are a **** stick driver then the SST would probably be the better bet. One miss shift and a blown up engine will quickly narrow that investment gap between an SST and a manual.
The thought of a SST rebuild scares me lol. I've installed clutches before...but was just curious what would be a better platform to build on. It seems people prefer the gsr for sure.
So really it comes down to end goal. I had an MR that was awesome with just boltons and I never wanted more. Car was very fast, but I didn't 'need' more power and that was a safe place for the MR. Basic boltons+great tune
What else do you gain? Ease in traffic and a sixth gear. While that seems minor, it is a lifesaver if you need it, and that sixth gear is a godsend on the highway. The GSR howls at 3500 RPM's at 65mph... that's ...rough. So the MR gives you more 'liveability' for a hopped up EVO. And it is VERY fast to shift and drive with, so you can find a different type of fun than rowing the gears based on precision driving and to the limit responsiveness.
So know your end goal, then decide. The SST is a great platform if you don't go full potato.
Bit of both really, as long as your goals are not 500hp you can run either safely, with great results. The SST just shouldn't be pushed past 350lb tq, and should only be tuned by the best out there to ensure it doesn't have issues. I'd suggest the same thing for the GSR, but the tune isn't as picky due to the lack of the SST but I would still use the best for either car, personally.
So a MR could handle a pretty decent amount? If i did decide to go full potato down the road which...wont happen for quite a long time. Is there enough mods for the SST to handle the HP i want? I dont buy bad parts for cars. I only ever put in whats best for the car. So if i cant afford the best i wont do it until i can. Especially with mitsubishi's.
You need deep pockets to make big power with an MR and there is no guarantee it won't have issues.
Adding this in there, the manual trans is pretty balky in the morning in cold weather. A couple of times I was sitting for a minute trying to get it in gear (without forcing it!) to get it moving.
If you're talking about going into reverse cold, try putting it in first, then putting it into reverse. Reverse is comprised of 1st and 3rd gears meshing together somehow, so doing that smooths out going into reverse most times. Give it a shot
Reverse is just first gear with basically one more non synchronised gear to cause the transmission output to rotate backwards. So yeah getting it into first before reverse usually helps. For those mentioning it being hard to get in, mine was that way on the stock clutch and before the transmission got freshened up. Now it goes into any gear at any RPM at any temperature without any drama.
The SST is fine between 350 and 400 ft-lb torque. However, it is NOT fine without cooling upgrades on the track. I have three coolers just for the SST. If you want to make more torque your looking at upgrading the block anyhow so you don't vent your block. So you if you plan for over 350-400 ft-lb of torque your looking at upgrading the SST clutch pack which is about $3500 bucks. I shopped a few places and that was about the going rate. I decided to keep my torque at 330ft-lb or so and everything has been fine. The SST needs to be WARMED UP before you get on the jam. A lot of guys who smoke the trans (aka: glass the clutch pack) get on the gas before the transmission is 150F. That is around the magic temperature that the retarded SST ECU stops INTENTIONALLY slipping the clutches in an attempt to warm itself up. I am not kidding here. From a gears standpoint the trans is built like a brick $hithouse. There are some weaknesses like sensors held in place with glue, but again if you keep the transmission cool then those don't detach and wreck havoc. Not sure if I helped the conversation here or not.
