Sponsored by:
Sponsored by: CARiD
15 evo x exhaust
Old Oct 10, 2017 | 05:47 PM
MuffinMan92's Avatar
15 evo x exhaust
I just ordered a titanium exhaust system for my 15 evo x. It was ordered from top speed. The exhaust comes with a test pipe and no cat or high flow cat. If I don't want to remove my cat, would I be able to just use this system as a cat back system and not install test pipe?
If I installed the full system, would I have a engine light for removing the cat and is there a way to clear the engine light?
thanks for the input- new to evo x modding. Had my car stock for a while, time to start playing.
Old Oct 10, 2017 | 09:15 PM
Honeymelon's Avatar
You should be able to bolt up everything up to the stock cat assuming flange fitment is on point, but since you have the test pipe you might as well use it, you will not regret it. Probably one of the better exhaust mods for the Evo in my opinion. If the test pipe has an extended bung for the O2 sensor you should be fine and it shouldn't throw any CEL's.
My test pipe came with an extended bung and I haven't had any problems with CEL's.
Old Oct 11, 2017 | 09:44 AM
static_set's Avatar
I don't believe the TSP1 test pipe will have an extended rear 02 welded on - if you do use it, may want to look into getting an extension from Touge Factory like this:
http://www.tf-works.com/tf-super-sho...ainless-steel/
thirty bucks or so and it'll keep that pesky CEL in the dark.
-ash
Old Oct 12, 2017 | 06:16 AM
ChipperEvo's Avatar
If you want the exhaust on with out the test pipe, it is totally fine.
You will have to get a tune for the test pipe also if you decide to put it on.
As mentioned above, test pipe, 3 port and tune is the best bang for your buck mod you can do.
Touaman
26
Oct 15, 2010 07:15 AM
juzdyn
Sep 2, 2009 06:35 AM
Mark H - Evo 8
Aug 26, 2007 01:35 AM
Chris@nolimitmotors
Jul 30, 2007 11:21 AM
500whp.com
15
Jul 15, 2004 06:47 PM
