Sponsored by:
Sponsored by: CARiD
AntiSurge porting on stock turbo?
Old Oct 20, 2017 | 10:33 AM
ossimbrian's Avatar
I'm all about maximizing the stock turbo (not turning it into an fp green or whatever), and i've done alot of readings on anti surge ports.
Aside from preventing Compressor surge, there's debate saying that a ported housing reduces spool on the low end by up to 500rpm, but can hold higher boost at the top end of the RPM due to a lower mass flow. My opinion is that this debate depends strictly on the size of the compressor.
Has anyone thought about this? I'm thinking of porting the stock evo x turbo for that high end gain. Do you think on the stock turbo, higher end gains will be the outcome?
P.S. Theres alot of metal on the compressor side to make a good port therefore do-able.
Old Oct 20, 2017 | 11:10 PM
4b11slayer's Avatar
Invest elsewere
Old Oct 23, 2017 | 08:03 AM
LetsGetThisDone's Avatar
The stock turbo is simply out of air once the car is on E85. Save the money for a turbo upgrade.
Old Oct 23, 2017 | 10:58 AM
RazorLab's Avatar
If you are going to have the turbo out, just upgrade. There are plenty of options. Even just upgrading the compressor wheel would give you much better top end.
kanyonkid
Sep 21, 2010 08:46 AM
assembeldbygod
May 1, 2008 06:18 AM
Top_End_EVO
Jun 11, 2007 02:11 PM
blackonblackevo
May 12, 2007 07:35 AM
talentsearch301
38
Nov 4, 2006 08:21 AM
