Sponsored by:
Sponsored by: CARiD
Need Advice on how to Remove Hotside of Turbo.
Old Nov 29, 2017 | 02:47 PM
Luis Macias's Avatar
Solved
Tried installing my Open dump but I ended up snapping a bolt so I decided to remove the hotside of the turbo. I took off the Clamp and I believe I have all the bolts out to remove it but I still can't figure out how to seperate it. Am I doing something wrong?
Old Nov 30, 2017 | 07:33 AM
bolothedv's Avatar
I can't tell, but is your wastegate arm still attached?
Old Nov 30, 2017 | 08:38 AM
splattj's Avatar
The Wastegate will need to be detached. Also, it's a tight fit so tapping it with a rubber mallet might help. It's not just going to fall off once everything is unbolted.
Old Nov 30, 2017 | 09:40 AM
six40's Avatar
Did you make sure you removed all the mounting fasteners that keep it attached to the block? They're sneaky in there. If they are all out, yeah a love tap with a rubber mallet or even a hammer with a block of wood will free it up nice.
Old Nov 30, 2017 | 11:48 AM
I have it unbolted and hanging in the back.
Old Nov 30, 2017 | 11:53 AM
I tried hitting it with a rubber mallet and a hammer but it wouldn't budge. I ended up putting a screwdriver and hitting it with a hammer. That did work but it didn't look pretty at the end but I don't think it will cause a leak when I install it back.
DisgustipatedM3
Mar 1, 2013 02:50 PM
khasal
For Sale - Part Outs
26
Sep 28, 2012 08:08 AM
Braydo25
May 16, 2010 11:13 PM
Johnboy1065
Mar 2, 2009 07:14 PM
IDRINKV8
12
Sep 21, 2006 01:47 PM
