Hey all. Not sure what this leak is, my garage is currently being used as a cat shelter by the wife, so I'm not able to get under the car until Saturday. But, there appears to be oil leaking from somewhere behind the wheel well/above fog light housing. Bought the car Wednesday(As is. Nothing I can do about bringing it back to dealer.), so I don't have much experience with it or how the moving bits are laid out. Does anyone know what this leak could be, or what parts are near this area so I can get an idea of what I'm going to be dealing with over the weekend?
Sorry for picture quality, best angle I could get without it being in the air.
Well I was able to get the front bumper yanked off. oil cooler is fine, the lines are coated in oil but don't appear to be the source, the leak started coming from directly under the pan once I got rid of the undertray. which is somewhat of a relief. I hear gaskets failing are common. Also found the reason why my passenger side fog light hasn't been working. They were converted to LED bulbs by the previous owner, and the battery pack or whatever the hell it is is missing from that side. I also found out while I was down there that the undertray was half held on by zipties. So that's going to be a gargantuan pain to put back together.
This went well past midnight, so I'm putting off putting the damn thing back on till after work tomorrow.
That's exactly where the factory oil cooler is located. It could be that or one of the lines.
You are correct. Got under the car, and it was either coming from the oil pan or the cooler lines. Had dealership take a look as well to double check while they were bleeding the ayc pump (They never ended up doing that. Bled the ACD instead so I have to go back again.) and it was indeed the cooler lines. Problem is they want $1,000 to fix it. So I'm just going to buy a mishimoto cooler for $500 and replace the whole assembly.
Do not buy a mishimoto cooler kit. The heat exchanger is garbage. But the oil cooler kit from MAP. They use a genuine Setrab oil cooler.
Appreciate it. But as of about an hour ago I found a much larger issue. Seems like in the process of the dealer taking a look at it, they made the leak far worse. This was 30 seconds of idling in the driveway.
They charged me $800 for the privilege of rendering my car undriveable. Going to have to have it towed or wait until I fix it myself.
