Sponsored by:
Sponsored by: CARiD
Intermittent Cruise Control
Old Jun 7, 2019 | 12:09 AM
simondo's Avatar
I have an an issue with cruise control I recently fitted in sometimes it can be switched on and sometimes it can't.
GSR SST FQ300
I have noticed a couple of things, some of which from the forums:
1. I have aftermarket rear LED lights fitted (not by me)
2. I noticed that the cruise control dash light went off when my headlights came on in auto mode
3. If I turn on ignition without starting engne for a period of time (e.g. adjust dashcam, program aftermarket DAB) on starting engine I lose cruise control. In this case it is only able to be switched on after a long period of ignition off
I strongly suspect from forums that the LED rear lights are to blame due to resistance issues, especially given 2 above.
I have tested brake switch and it is adusted correctly.
My question is twofold:
Is it the rear LED lights causing the issue?
Does any one have a definitive resistor value to put in series for LED rear lights to so that resistances matches stock lights?
Thanks.
Old Jun 7, 2019 | 08:23 AM
Metal_AF's Avatar
To me - these two things sound like you are shorting out the circuit someplace.
