Sponsored by:
Sponsored by: CARiD
Coilover Bracket Clearance with Ohlins R/T
Old Oct 16, 2019 | 11:35 AM
LaggyEvo's Avatar
Has anyone had issues with their brake line bracket contacting the brake hardlines in the front fender wells, or even the fender well itself with coilovers and negative camber? I am running Ohlins Road and Track with about -2.5 deg of camber and noticed the other day that my passenger break hardline was almost worn through due to contact from the bracket holding the brake lines onto the coilover. Has anyone encountered this issue and what did you do to fix it? Is it possible to trim the bracket? I have attached pictures of the damage, and you can see the white spot where it hit the inside of the fender.
Old Oct 19, 2019 | 09:34 AM
LetsGetThisDone's Avatar
I bend the bracket so it doesn't hit stuff.
Nzo
Jun 5, 2014 03:21 PM
Chukee_R
MitsubishiParts.net - WA
Feb 3, 2011 07:26 AM
todaysivxx
18
Mar 5, 2010 08:45 PM
evo8fl
Southeast Region
May 26, 2009 11:50 AM
kekek
Apr 11, 2005 06:12 AM
