Sponsored by:
Sponsored by: CARiD
gauge shows only 13PSI when WOT? normal?
Old Dec 21, 2019 | 09:35 PM
Kai Man's Avatar
Hi Guys,
i Just install a VLS boost gauge
when the car at idle is van at about -20psi which is normal,
but only 13PSI at WOT
i read some treads said its normal, some said should be around 18-20
i m so confused, my car is stock , only got a hks catback exhaust.
my question is that a normal PSI on a stock EVO
thank you guys
Old Dec 22, 2019 | 11:36 AM
Warhawker's Avatar
It should be at or just below 20 psi. Are you sure the gauge units are in PSI?
Any boost leaks (piping changes, engine work that would have disturbed them)
I don't think that's normal, if it's running OK and not spewing black smoke I'd bet it's the gauge or how it's installed.
The catback should have little change on indicated boost, if anything the easier flowing exhaust might increase your turbo performance.
Old Dec 22, 2019 | 12:09 PM
RazorLab's Avatar
13-14psi is wastegate pressure. Stock PSI is 20-21psi
nerdbotSKRA
May 30, 2013 09:33 AM
HighwayStarX
Sep 11, 2008 12:27 PM
N8THEGR8
Jan 16, 2008 05:07 PM
Smogrunner
Sep 25, 2006 09:57 PM
RedLanEVO
Sep 8, 2006 03:38 PM
