Sponsored by:
Sponsored by: CARiD
Mechanical Baffles in Exhaust
Old Mar 26, 2020 | 06:05 AM
Batang_Pinoy's Avatar
So you know how a lot of modem cars have the option to open up the exhaust making it louder by the push of a button? Is anyone aware of an aftermarket option that could be plugged into an existing exhaust? I'm thinking for when i pull into my neighborhood.
Old Mar 26, 2020 | 06:18 AM
splattj's Avatar
Hooker makes a pretty slick one that's adaptive and programmable but it's not cheap!
https://www.holley.com/products/exha.../71013003-RHKR
Old Mar 26, 2020 | 10:19 AM
Thank you! I was not sure what they were called.
Old Mar 26, 2020 | 11:38 AM
TDA78's Avatar
I use one of these at my muffler.
http://www.epmanracing.com.hk/Exhaus...p-cut-cl-boost
I wouldn't trust it in a hotter location. It starts opening at 5 PSI. My fabricator said they are more reliable than the electric valves. It is rusting after one winter on salted roads.
Old Mar 26, 2020 | 01:50 PM
splattj's Avatar
I'm guessing you have to adjust the rod so it's partially open under vacuum unless you're using it for a cutout. Definitely the cheaper route!
Old Mar 26, 2020 | 02:34 PM
TDA78's Avatar
I'm using it as a cutout in one tailpipe of the T1R 76S muffler. Makes a quiet exhaust even quieter, especially on startup, idle and deceleration. I just remembered I'm actually using the 63 mm model for that.
Old Mar 30, 2020 | 04:15 AM
Capt_Insano's Avatar
That Holley unit looks like they know what they are doing. I don't personally have any experience with these systems, but my concern with all these inline flappers is that they would create some unwanted back-pressure when closed. Also, I wouldn't think that they would make the car any louder when open, just quieter when shut.
For an alternative option, X-Force makes something called a "Varex" exhaust. It uses a flapper, but having it open vs. shut changes how much exhaust goes through the muffler vs. straight pipe. When I finally change out my exhaust, I plan to incorporate one of these. Also might be cheaper than the Holley system.
https://xforceusa.com/varex-mufflers/
Along with the standalone muffler, MAP also sells a full cat-back with one of these things.
https://www.maperformance.com/collec...vo-x-evox-vcbe
Old Apr 2, 2020 | 01:45 AM
this deff looks like a great temporary try it out part. Esp since i live where they dont salt roads.
janvin21
Dec 10, 2008 09:12 AM
ams evo
10
Feb 22, 2007 05:02 PM
RaDZio
13
Dec 1, 2003 09:09 PM
